viewfinder brightness !
Posted 22/04/2010 - 16:55
Do you mean the back panel LCD brightness?
(There's a setting for that!)
The viewfinder has no brightness controls - it's optical
And the digital display doesn't have a brightness... I often find cupping my left hand over the viewfinder and my eye helps in bright side lighting.
Posted 22/04/2010 - 17:17
No not the LCD display. As seen through the viewfinder. It sometimes brightens up of it's own accord (bright light perhaps?), so wondered if I'd missed a setting somewhere Do you mean the back panel LCD brightness?
By digital display, do u mean on the top ?? If so that has a button to illuminate, of course.
The left hand trick is what I use, but as a glasses wearer I'm even further from the viewfinder
Posted 22/04/2010 - 17:20
Posted 22/04/2010 - 17:28
Anvh wrote:
Stu means the green display showed here, I believe.
I believe it has 2 brightness settings which work automatically but you can't control them in anyway.
Mine looks yellow !? but what the hell !! Stu means the green display showed here, I believe.
Any idea what triggers it Stefan ??
Posted 22/04/2010 - 17:36
Yellow/green what ever you want to call it Mine looks yellow !? but what the hell !!
I believe it use the EV meter and when it's dark it dims the display and when it's bright it brightens it.
Posted 22/04/2010 - 17:46
Anvh wrote:
[quote:3496ace15f="stu49"]
Not enough ! obviously !! lol
Posted 22/04/2010 - 18:39
Just engage the optical preview!
If the view finder picture is bright then the pupil of your eye will be small letting in a small amount of light.
If the viewfinder picture is dull then the pupil of your eye will be larger letting in a larger amount of light.
When the pupil of your eye is larger then the green display will appear to be brighter.
Engaging the optical preview will stop down the lens, let in less light (unless lens is fully open of course), viewfinder picture becomes darker, your pupil becomes bigger, information display becomes (apparently) brighter!
The limit to this is of course the diameter of the image exiting the viewfinder as of course if your pupil diameter needs to ge bigger then there will be reduced brightness.
Good luck
Bob
Bob
Posted 23/04/2010 - 15:21
Nice idea !!Just engage the optical preview!
But don't work !! Preview blanks display !!
Try again ! lol
Posted 23/04/2010 - 15:25
If Pentax bring out a FF DSLR??? That will have a brighter viewfinder by default.
Posted 26/04/2010 - 11:02
stu49 wrote:
Nice idea !!
Try again ! lol
Ah well - some you win and some you loose...
Nice idea !!
Try again ! lol
Good luck
Bob
Bob
Posted 26/04/2010 - 11:23
It'll make no difference to the brightness of the in-finder information display.If Pentax bring out a FF DSLR??? That will have a brighter viewfinder by default.
K.
Posted 26/04/2010 - 14:14
womble wrote:
K.
K.
What you could do is aim the camera downwards to the ground, but don't know if that's usefull?
Also you can adjust your camera using the top LCD screen.
UK
Just been out in bright sunlight and couldn't see a thing !!
