Vietnam lady
Posted 26/05/2008 - 17:54
Very nice image but I think that it looks slightly 'detached' without a background.
(Hope I don't go that wrinkly)
Hyram
Posted 26/05/2008 - 18:03
I wonder if she has any trouble finding the hole for her ear rings to go through.
Nice shot, but yes, it does look a little odd with nothing in the background.
Dan
Dan
Posted 26/05/2008 - 19:49
Her face could do with an ironing
Sorry, couldn't help myself. I don't think I'm qualified to comment on the picture, but I like it, well done.
K100D Super, Kit 18-55mmF3.5-5.6 AL, Tamron70-300mm F/4-5.6Di, 2005 GSX-R750, 1991 VFR400 NC30 road bike, 1989 VFR400 NC30 track bike
Posted 26/05/2008 - 20:17
I'd say it does need a background as at the moment the sides of her head seems to melt into the white of the background in an odd way. In fact I find the skin very odd to look at. I don't think it's the monochrome that's doing this but the bits between the wrinkles look quite waxy.
It doesn't look as sharp as your usual photographs either.
I'd be very interested to see how you introduce a background and how effective it is. then I'll ask how you did it!
Mike on that learning curve!
Posted 28/05/2008 - 12:24
Posted 28/05/2008 - 12:40
It makes a huge difference. Very nicely done.
Did you try to add some sharpening by using highpass filter(s). I recon that it would be good to use in this situation without any noise.
Posted 28/05/2008 - 13:49
Lilly I'd be pleased to know how you made such a neat job.
Posted 28/05/2008 - 14:37
Thank you Mike, here you are then:Lilly I'd be pleased to know how you made such a neat job.
I use PS CS3
Select the background with magic wand or lasso
REDEFINE EDGE command, feather to suit approx 55 pixels; adjust/contract to suit
I opened one of my free texture background files I got free with a mag, select all, edit, copy
Back to original file, edit, paste into
when on textured background layer, Image, adjustments, curves or levels to match the lighting of foreground
Tidy up on original layer with dodge & burn as required
All there is to it! (did spend a wee while working it out, tho')
Lets see your attempt next!
Posted 28/05/2008 - 14:40
Yes, I have tried that High Pass before but didnt think to do it on this one so I did an overall sharpen and de-noised it a bit which is why I think because of the film grain it has turned a bit soft and waxy, but heh, I like it anyway, thats what matters, but will try again HP way.
Posted 28/05/2008 - 14:45
Thanks Lilly I'll try that sometime. I suspect I'd be a bit impatient and ham fisted with the edges!
Posted 28/05/2008 - 15:00
Yes, I have tried that High Pass before but didnt think to do it on this one so I did an overall sharpen and de-noised it a bit which is why I think because of the film grain it has turned a bit soft and waxy, but heh, I like it anyway, thats what matters, but will try again HP way.It makes a huge difference. Very nicely done.
HP filters just seems to be a good way - with this kind of picture. You have a lot of "structures" in the face that can be sharper with that filter (fills the gaps).
Posted 28/05/2008 - 15:05
try and get in touch with your feminine side and I am sure you will manage OK
Duchy of Cornwall
Pentax Z1 Tri-X 400
BLOG
FLICKR
