UV or not UV
Posted 06/02/2010 - 14:34
UV has almost no effect on digital, so there's no need for a UV filter to improve image quality.
You can use one for protection if you like, or a clear glass protector, but one can cause ghosting or slight loss of image quality, and you have another two surfaces to keep clean.
Lens glass and coatings are actually quite robust and are only damaged if you're exceptionally unlucky or careless, especially if using a hood.
~Pete
Posted 06/02/2010 - 14:51
It may be illogical, but I would rather clean a filter than the front of a lens.
Barrie - Too Old To Die Young
Posted 06/02/2010 - 14:56
AHA
Iceblinker said
So why are some lenses supplied with hoods and others aren't ?
Iceblinker said
Lens glass and coatings are actually quite robust and are only damaged if you're exceptionally unlucky or careless, [b]especially if using a hood]/b].
Now the kit 18-55 on the K-x does not come with a hood but the Samsung 18-55 that came with my 50-200 does come with a hood.Lens glass and coatings are actually quite robust and are only damaged if you're exceptionally unlucky or careless, [b]especially if using a hood]/b].
let the education continue
Posted 06/02/2010 - 15:04
My 18-55 came with a hood in the kit.
Posted 06/02/2010 - 15:08
Hoods are left out to pinch pennies, sadly.
You can however get one for your DA L 18-55: http://shop.ebay.co.uk/?_from=R40&_trksid=p3984.m38.l1313&_nkw=PH-RBA*&_sacat=Se...
~Pete
Posted 06/02/2010 - 15:10
Usually no hood is supplied with the DA L version.
~Pete
Posted 06/02/2010 - 15:27
Anvh wrote:
Thanks for the link - now I know how to clean properly...
I would be really careful with your glass though they are so fragile linkLens glass and coatings are actually quite robust and are only damaged if you're exceptionally unlucky or careless, especially if using a hood.
Pentax K50,FA 35 2.0,FA 50 1.4, DA 18-135 WR, Sony RX100 2, Manfrotto bits...
Posted 06/02/2010 - 15:44
Yes that's the extra light version (DA L) and comes without a hood the rest of the current pentax lenses come with an hood.Now the kit 18-55 on the K-x does not come with a hood but the Samsung 18-55 that came with my 50-200 does come with a hood.
I believe with Canon they never come with one
Posted 06/02/2010 - 15:46
The hood is a very important, if not vital, accessory and happily comes with almost all Pentax lenses except the very lowest cost ones.
Posted 06/02/2010 - 15:49
OK - so why ?
As I can see from the 3 lenses in my house - there's more than one type of hood ?
Posted 06/02/2010 - 15:57
technoidiot wrote:
OK - so why ?
They didn't include the hood to save on cost most likely, the DAL versions also miss quick-shift and an metal lens mount.OK - so why ?
You've different kind of hoods because you've different kind of lenses.
They try to make the hood as close fit to the lens as it can so that it works better.
an wide-angle hood is for example much wider and zoom lenses often come with a flower hood since it allow for a bit more protecction for the sun.
Most prime lenses come with a simple round hood that covers that focal length perfectly.
Posted 06/02/2010 - 16:02
A. Lenses come with a hood if one is needed.
B. All lenses come with a lens cap. Go figure.
I shoot around the city. I take the lens cap off, take a photo or a few photos, and put the lens cap back on. On some occasions, a procession or parade or dance program, I might leave the lens cap off for quite some time but, as a born klutz, if I'm changing location, the lens cap goes back on.
I enjoyed the video of the torture test for a lens but I decided not to try to duplicate his test with one of my lenses.
Posted 06/02/2010 - 16:17
That's not true, a lens hood will always help against flaring and glares. Okay some lenses are less prone to that but still an hood is the best solution against that.A. Lenses come with a hood if one is needed.
You can compare it that you cover your eyes when you need to look against the sun, it simple blocks the sun or light source sometimes to shine directly on your glass.
London
Hi, also bought a Kx recently for much the same reason as Derek and starting to learn, Decades ago when I had a film SLR it was common practice to have a filter (I think UV) fitted which stayed on permanently - as much as to protect the lens as to improve photos I think.
Gazing at my pristine new lenses (bought a zoom as well) - is this a good idea and if so what type of filter should I fit??
Thanks in advance for help.
Hmmm - I think there are 2 views here Some say you should put a UV filter on and others say don't .
I've a UV filter on my K-x's 18-55 and, till I get another one, I change it to the 50-200 if I'm using that. Sorry don't think I've helped you at all
Welcome to the Forum BTW
