USM and DA* 50-135mm
Posted 07/06/2009 - 18:50
Errr, 18 months...
Posted 07/06/2009 - 18:51
Damn, you beat me to it-I have a habit of not reading things properly first time.
Posted 07/06/2009 - 18:52
Me too...
Posted 07/06/2009 - 18:58
Back on topic though it will still be under it's 2 year warranty - I assume it's 2 years?
Posted 07/06/2009 - 18:59
I thought Lenses also had a two year warranty if bought from a pro dealer? and didn't you buy from SRS?
As for the quality of the lens hood, mine has also broken and is now a very slack fit, I thought about asking for a replacement but TBH I cant see it lasting any longer due to the flimsy design.
EDIT remind me to never get into a gunfight with snootchies, he has a faster trigger finger
Posted 07/06/2009 - 19:03
I bought the lens from 17th Street Photo in New York, not SRS.
Posted 07/06/2009 - 19:22
I understood all lenses have a two year international warranty from Pentax. Worth asking anyway.
Posted 07/06/2009 - 20:02
Womble,
You may have to do a little pleading with Pentax UK.
The warranty on US purchased items is just One Year. Bodies can be registered for an extended warranty but not lenses.
Posted 08/06/2009 - 09:58
I have heard that if you interupt the two contacts for SDM, then the body will think it's a screw drive lens. Not sure what the best way of doing that is though.
As I understand it, there is no way for a DA* lens to flip between SDM or screw drive as and when; it will always try for SDM so you need to 'trick' the body.
Something to consider if you dont get anywhere with a 2yr warranty.
Posted 08/06/2009 - 10:20
A small piece of insulating tape over the lens contacts should do the trick. Easily reversable so no warranty violation.I have heard that if you interupt the two contacts for SDM, then the body will think it's a screw drive lens. Not sure what the best way of doing that is though.
Posted 08/06/2009 - 10:23
I don't think that works. I've tried a DA*300 with a AF Teleconverter with no SDM contacts and the lens would only Manual Focus. I've been told SDM lens will only use the screw drive if the camera body is not compatibale with SDM.
Barrie - Too Old To Die Young
Posted 08/06/2009 - 10:32
bforbes wrote:
That's a shame. Well..it was an idea...
I don't think that works. I've tried a DA*300 with a AF Teleconverter with no SDM contacts and the lens would only Manual Focus. I've been told SDM lens will only use the screw drive if the camera body is not compatibale with SDM.I have heard that if you interupt the two contacts for SDM, then the body will think it's a screw drive lens. Not sure what the best way of doing that is though.
Hertfordshire,
mostly.
Cheers, Kris.
