Using UV Filters
Gajan
Posted 16/12/2013 - 09:08 Link
Thinking of getting a 62mm UV filter for my new 18 -135 WR mainly to protect it from scratches etc.
Does it have any effect on image quality? Any particular makes you are happy with or to avoid? Are the expensive HD versions really worth the extra investment?
I would appreciate any input based on your experiences.
Best Regards,
Gajan
Best Regards,
Gajan
Flickr : link
Pentax K-1, D-FA 28-105mm, FA 77mm, D FA 100mm Macro
Pentax K-5, 18-135 mm, 55-300mm
Pentax K100D Super, 18-55mm
ChrisA
Posted 16/12/2013 - 09:45 Link
Most people here recommend a hood rather than a filter.
It's a topic that comes up about three times a year, and the answers boil down to:
- Don't use one: why buy an expensive lens and then stick more glass in front of it, given that the coating is pretty tough anyway, and if something breaks the filter, it's likely to badly scratch the front element.
- Use one if you want, it makes very little difference unless the filter is a cheap crappy one, and fingerprints are more likely than scratches.
Posted 16/12/2013 - 10:03 Link
That's a sort of summing up from ChrisA, but to be fair there are those who have experienced filters fragmenting and damaging front elements. I'm not sure that anyone who uses a hood has damaged an unprotected front element.
Save your money, unless you are so clumsy that you stick your fingers all over the front element. In which case it would happen even more to a filter.
Filters that are useful are ND grads, polarisers and UV/Skylight if there's going to be a lot of salt spray hitting the lens. Apart from that, save your money and always use the hood.
Gamka
Posted 16/12/2013 - 10:19 Link
I am of the use a filter side of the argument. However I tend to use a Protector on most lenses although a couple do have a UV.
If you do decide to go with a filter then look at:
The Hoya Pro1 range (which mine are) http://www.hoyafilter.com/hoya/products/pro1digitalfilterseries/
or the Hoya HD which are a newer "improved" version http://www.hoyafilter.com/hoya/products/hdfilters/
They are not cheap and to me the argument about putting a filter in front of an expensive lens needs further consideration. Simplistically: A DA*16-50 is around £900 and contains 15 lens elements leaving assembly and teh barrel aside that is about £60/element. An HD UV filter will be £90 to £100 ... It does suggest that a lot of care is taken in designing and manufacturing the filters.
And a word of warning. Think three times about buying a bargain one off an auction site ... there are a lot of fakes out there.
ChrisA
Posted 16/12/2013 - 11:50 Link
Sort of?
I did say, "and if something breaks the filter, it's likely to badly scratch the front element"
Not sure what you're getting at John. I thought that was a pretty fair summary of the two main views.
Edited by ChrisA: 16/12/2013 - 11:53
gartmore
Posted 16/12/2013 - 12:09 Link
I'm with ChrisA and John on this and have personally had a lens damaged by a breaking filter. I'll only add that the front element is way tougher than any filter.
Gamka
Posted 16/12/2013 - 12:25 Link
Just thinking back to around 1978 ... two of us were doing a series covering casting from making the wooden patterns, sand moulds, casting, fettling and basic machining. In that environment there can be some real nasties flying around and changing films meant leaving the building to stop dust entering the body and lenses were never changed.
At the end of it, my filter was ruined and the other photographer had a damaged front element. In both cases particles had welded themselves on.
Horst
Posted 16/12/2013 - 12:32 Link
Every piece of glass, no matter how plain and what coating it has, introduces some flair. Compared to nothing any glass is a cloudy thing you put in front of your lens.
The only exception is suppose would be a polarizing filter,
or special purpose filters and in the old days with a B& W film day a yellow filter.And with old lenses an UV filter for colour. (Old glasses where not UV absorbent)
However a lens shade ( Lens hood, Compendium),is a must for any lens, except a deep seated one, like for example the Pentax-A 50mm f2.8 macro.
A lens hood can only do good and never be bad. It even protects your front element from rain. I have quite a few lenses , Old and new types. but every one has and is stored with a lens hood.
Regards, Horst
Edited by Horst: 16/12/2013 - 12:33
Posted 16/12/2013 - 12:43 Link
Maybe so, but that simply comes under circumstances where a filter might have to sacrificed. Common sense to use one. The salt water spray example offered is similar. In adverse conditions, we protect camera and lens, but not all the time.
petrochemist
Posted 16/12/2013 - 12:51 Link
Whilst I'm with John/Chris/Ken/Horst on this I think it's worth adding that there are some rare occations where a filter might be a good idea.
If your likely to be getting salt/dirty water spray around (not so rare with WR cameras) add a filter (even a relatively cheap one) till clear of the spray.
I've used them to hold a Bokeh mask in place between the lens & the filter).
They may come in handy for full spectrum converted cameras.
The main arguments for UV filters comes from film days where the sensing medium was sensitive to UV. These days the sensor it coated to prevent UV sensitivity.
Posted 16/12/2013 - 12:55 Link
Perhaps sales people being constantly pushed to sell "add ons" when selling a camera could also be a factor? The profit for retailers could lie in the filter, case, maintenance kit and insurance that they want to add on to every sale.
Gajan
Posted 16/12/2013 - 17:30 Link
Thank you all for your input. I think I will leave the UV filter out and may consider keeping one in the bag in the future for use when the situation demands.
I feel just the hood or the cap will do for now.
Best regards,
Gajan
Best Regards,
Gajan
Flickr : link
RalphHardwick
Posted 16/12/2013 - 18:49 Link
I always leave a UV filter on my lens unless I'm specifically aiming to get the absolute best photograph I can. I always get a filter with every lens I buy as you can often get a deal on the filter price.
I would love to claim that a filter would have a detrimental effect on my images but 80%+ of the images I take fall into the family snap or general memory category where you would not notice any difference. When I deliberately put extra effort into capturing a specific image then I remove the filter just in case. Also where I feel there may be potential for 'extra' flare I take it off.
For 10 years I travelled as an engineer in the Merchant Navy. My Pentax K1000 and Olympus OM2 travelled on planes, boats, and trains, in backpacks up mountains, on deck in rough seas and in a variety of uncomfortable and rough locations. The camera bags back then were nowhere near as padded and protective as they are now and in all that time I never had a problem with broken filter. However I did have, sea spray, diesel and any number of other unmentionable fluids and fingerprints which would have ruined the lens.
In the last 5 years I have travelled extensively with my Oly E520 and Pentax K5iis and, again, have never suffered a broken filter but have been very grateful that I had them fitted.
For me the risk of goo on the lens and the slight chance that the filter will cause more damage than the impact that broke it are much higher than the risk of a minimal reduction in image quality. But that's just me
CaptureLight Ltd
flickr
Edited by RalphHardwick: 16/12/2013 - 18:51
bwlchmawr
Posted 16/12/2013 - 18:53 Link
RalphHardwick wrote:
I always leave a UV filter on my lens...
I quite agree.
Best wishes,
Robert Adams
Ernst Hass
Russ
Posted 16/12/2013 - 19:06 Link
Only have one screw in filter and that is a Hoya CPL. All three of my lenses are 62mm, so just one filter needed.
I use to stick a cheap UV on all of them up till last year but then read i was probably degrading the IQ, so ditched them all. Just make sure a lens hood is in place unless using the Cokin filters.
