Using TV Mode on a Pentax K3
Posted 27/11/2016 - 23:29
You didn't bump it with a front or rear dial movement by mistake?
Posted 27/11/2016 - 23:40
Hi
No I hve just tried it again here at home and it is still changing ?
Marmimag
Posted 27/11/2016 - 23:49 - Helpful Comment
Have a look at Custom Menu Auto EV compensation. If activated, this might change your shutter speed when the range of apertures available cannot secure correct exposure.
Posted 27/11/2016 - 23:54
Many thanks John!
You're a star!
I did have it switched on ! Must have set it up for something earlier!
Phew!
You're a star!
Phew!
Marmimag
Posted 28/11/2016 - 06:52
I have a K7 and K3 and have noticed with the latter that it seems easy to accidentally switch something on or off without realising, at least compared to the K7. Just saying.
London
I use the TV (Shutter Priority) rarely but when I did today on the K3 - I noticed that when I took the image the Shutter speed changed even thought I had it set on TV mode? I tried it with my K5ii's and it stayed on the same TV setting that I had set?
Any ideas why this is happening?
many thanks
Maggoi
