Using Pentax ME Lens
Myles
You will notice that the field of view changes as the digital sensor is smaller than a 35mm film frame (so a 50mm lens on digital will look like a 75mm lens did on film, etc). The lens in use will also determine in which modes the camera can be used. For example; a lens that is entirely manual (like a Pentax M-series) will require you to operate the camera manually (stop down metering, manual focus, etc) so generally more modern lenses are more convenient. Old prime lenses rarely give anything away in terms of image quality though.
You can use the earlier M42 lenses but you need an adapter, ideally a genuine Pentax one as some of the 3rd party types don't allow you to focus to infinity. The camera won't hold the aperture open, stop down to take the photo, then open it up again as it does with K mount lenses.
Pentax 18-55mm,50-200mm,Macro 100mm
Takumar-A 28-80mm, Sigma 170-500mm, Soligor Teleconverter x2
Finally!! Sigma 10-20mm
God, grant me the serenity to accept the things I cannot change, courage to change the things I can, and wisdom to know the difference.
https://pentaxphotogallery.com/maliskaoosthuizen
K-1ii,K-3iii's.
SMC PENTAX-F 1:2.8 28mm, HD Pentax-D FA* 1:1.4 50mm SDM AW,
SMC PENTAX-D FA MACRO 1:2.8 100mm WR,
SMC PENTAX-DA* 1:4 300mm ED [IF] SDM,
SMC PENTAX-FA* 1:4 600mm IF & ED,
HD PENTAX -DA 1.4x AW AF REAR CONVERTER,
Pentax Photo Gallery
Ray Whent
