Using old lenses with an adapter
Posted 05/04/2012 - 18:04
You're really asking on the wrong forum - there are no doubt Canon forums where someone will instantly know the answer.
Thye stop down pin on M42 lenses is actiavted by a plate on screw mount Pentax cameras. It doesn't work at all on K mount cameras, so they are used in stop down, manual mode. That is, we simply set the aperture we require, having set the lens to M (manual) - in this instance the auto/manual switch is referring to aperture control.
Don't know about the Helios lens as there are quite a few variations covering many years.
Posted 05/04/2012 - 18:10
Hi John,
You are right. It's just that I have come to respect and trust the advice that I have had from the regulars on this forum. You have never steered me wrong!
I'll have a look and see if I can identify a manual setting. Your reply gave me a direction for my google searches though and I found this:
http://www.pentaxforums.com/forums/pentax-slr-lens-discussion/57058-helios-44m-4...
It sounds like maybe you have to stick the pin down permanently to get it to work.
Thanks for your help.
London
With an adapter it should fit on fine but the only thing I don't understand is how the camera will stop down the aperture when a photo is taken. The lens has a small spring-loaded button on the back which when pressed closes the aperture. Will the camera be able to do that? Or is there a special process for using these older lenses?
I have never had to deal with adapters because all of my old lenses fit happily onto my K mount. Good old pentax!
Any help would be great.
