using ND filters
Posted 15/10/2012 - 10:15
No problem...
ND4 is 2Ev (two stops)
ND2 is 1Ev (one stop)
See: http://www.darktable.org/usermanual/ch03s04s12.html.php
If you have TTL metering, then the meter should be able to 'just work' - assuming that when the ND is added the exposure is not out of the exposure range of the meter
Posted 15/10/2012 - 11:12
ok I understand what your saying but does that render a sharp picture at the correct exposure without bluring the water or does the water blur naturaly because of the long exposure or do I have to add more exposure time to blur the water and will that cause it be over exposed .
in which case do I need a ND filter with higher density.
just trying to understand how it works.
Posted 15/10/2012 - 11:38
It is the long exposure time that blurs the water, adding the ND filter reduces the amount of light getting to the film/sensor and allows you to increase the exposure time. You may aslo need to opt for a narrow apperture setting to avoid over exposure.
At the sort of exposure lenghts to achieve this it is likley that you require a triod to get a sharp shot.
In the picture below i was able to get the affect by reducing the apperture without an ND filter (did not have one) as there was not much light.
Posted 15/10/2012 - 12:49
thats all quite clear thank you
if the exposure time is longer that the 30's that most camera's are able to meter to how do I calculate what exposure time I need withou over exposure or is it unlikely I need longer than 30's
Posted 15/10/2012 - 14:53
thank you that's exactly what I needed I have saved the files and will print them of and laminate them and keep them in me camera back
thank you tyronet2000 and eveyone else who replied
Christopher.
Christopher.
Falmouth,
Cornwall
ie: streams the sea etc to blur the water.
my question is, is there a formula or rule of thumb to
work out the exsposure time to achive this, the filters I
have are ND4's.
I know its probably the same for film or digital but just
to let you know I'm using a film slr.
Christopher
