using M lenses on *istD
Anonymous
Posted 05/03/2004 - 15:11 Link
I am thinking of buying an *istD but currently have 7 fantastic M lenses - can these be used on the *istD in manual metering mode ? if so is the *istD easy to use on manual metering ?
George Lazarette
Posted 05/03/2004 - 16:44 Link
You need to apply the firmware revision, available from the Pentax website, and then you can meter quite satisfactorily with K and M lenses.
Anonymous
Posted 07/03/2004 - 02:33 Link
It works great, it's as easy as setting camera to manual mode, set the aperture, push green button behind shutter release button, camera sets shutter speed, focus, shoot. The cool thing is that the auto focus system is still on, it beeps and gives you an in focus indicator in the view finder. Works very nice.
Anonymous
Posted 07/03/2004 - 09:13 Link
warning
p-ka compatible lenses will lock up on the KAF2 mount
no guarantee , no pentax lenses used,
175 euro repair and 15 days repair
the rico pin will lock up in the hole of the af driver
greetings
George Lazarette
Posted 07/03/2004 - 15:47 Link
I think the poster was talking about Pentax M lenses. The Ricoh problem is fairly well-known, but in fairness Ricoh don't suggest that you should use their lenses on Pentax cameras.
Joshua Hakin
Posted 09/03/2004 - 20:35 Link
I did the update... but my Pentax-M 50mm 1.7 only works at open aperture, I can't stop down to anything. The DOF preview doesn't work either!
Advice?
Joshua Hakin
Posted 09/03/2004 - 20:43 Link
Nevermind!
I just reread brew1's post and finally clued in!
Oh... relieved!
Anonymous
Posted 05/05/2004 - 02:11 Link
Didn't work on my M series 35 - 70 2.8 zoom. Anything I'm doing wrong?
Anonymous
Posted 05/05/2004 - 04:55 Link
Ah haa.... worked it out - had to fix up the custom function and turn it to Manual Focus.
