Using independent flash ( e.g. Vivitar 283 ) with K5?
Elleygreen
Posted 04/06/2011 - 12:48 Link
As a new user, having just moved on from my Mz5n, I understand that I could damage my K5 by using my Vivitar 283 with it - is this so? ( too high trigger voltage? )
Posted 04/06/2011 - 13:17 - Helpful Comment Link
It's possible because not all 283s are the same. I have measured two identical looking samples, one of which had a trigger voltage of under 20V but the other was around 290V. Obviously over the years the design has evolved.
I wouldn't risk it and would stick to modern flashguns, even though it may be OK if it's not you'll potentially fry the camera's electronics.
Elleygreen
Posted 04/06/2011 - 18:09 Link
Thanks John - but, as I feared, it is not only the K5 that is proving to be an expensive move to digital! ( Brilliant camera though!!! )
gartmore
Posted 04/06/2011 - 18:34 Link
It will still be useful as an off-camera flash with a remote trigger
DaveHolmes
Posted 04/06/2011 - 21:46 Link
+1 on that...
Digital:
Flash:
Film:
layingback
Posted 05/06/2011 - 07:25 - Helpful Comment Link
Check the place of manufacture (on bottom of unit). If it says made in Japan it is the older version and will be of the just shy of 300V variety. Made in Korea is latest and will be safe in general. But considering the value of the camera in question, a test with a digital voltmeter is mandatory really even if you have to buy one - a basic voltmeter will suffice - you don't need extreme accuracy to diff < 10 or 20v versus > 250V. Just charge flash off camera and discharge by connecting the meter across the contacts (with flash pointing a way from you
[ BTW 285HV's are also likely to be OK, but older 285's (without HV appended) can be any voltage. I have a very early 285 and it is low voltage, but later ones are not. Strange. So actual testing is the only way to tell. ]
Or - if yours tests out too high - pick up another later 283 and a cheap optical trigger and you have a 2-flash setup while avoiding having to learn a new flash model's operating procedure. That was the path I took.
Don
Posted 05/06/2011 - 15:41 - Helpful Comment Link
I do believe the older vivitars that are capable of frying your d-slr are the same ones that would have fried your mz5n... you should be ok to use it.
digikid-tv
Posted 05/06/2011 - 16:06 - Helpful Comment Link
I did some investigation work on the interface between the Pentax K10D, K20D and the Vivitar 283 when I needed to build an system to fire a number of them simultaneously. I have owned more than twenty of these units, but after selling a few I am currently down to my last seventeen! Here is a brain dump of what I found.
The K10D and K20D have a thyristor device as the switching component. High voltage is not a problem for this circuit and I have regularly used Vivitar flashguns with 270 volts on the hotshoe on my cameras with no ill effect. I would imagine that the K5 is the same.
As other posters have outlined, the voltage on the Vivitar 283 hotshoe varies with when the unit was made.
Original Japan units are 270 volts.
Japan made units with a red paper disc sticker on the inside of the battery door are low voltage (around 10 volts or so).
Korea made units are low voltage.
China made units are low voltage.
Circuits to modify the flashguns to low voltage trigger are available online and for various non Pentax reasons I have so modified a number of mine. Avoid those with an opto-coupler as these latch up the Pentax switching thyristor. Google for Jean Paul Brodier whose triac circuit I find to work well.
Most websites show horrible construction, it is quite possible to build an interface into the flash head without any detrimental effect on the appearance or function of the unit. The yellow wire is the trigger, the blue the common.
John
Don
Posted 05/06/2011 - 16:22 Link
My viv283's have potentiometers jammed in where the sensors were and peanut slaves.
Full manual control and ultra low power settings to use them for high speed or macro work.
Fine flashes, everybody should have them!
digikid-tv
Posted 05/06/2011 - 16:31 Link
Likewise Don. 5 modified to fully manual with potentiometers replacing the sensor, one modified to switchable between auto and manual. I use the Seagull triggers SYK3.
John
Don
Posted 05/06/2011 - 16:46 Link
that is the great thing about old stuff... if you are creative, you never have to throw it away!
Posted 05/06/2011 - 18:16 Link
But we can't assume that.
Anvh
Posted 05/06/2011 - 19:06 Link
From what i've read the Pentax are comfirm with the ISO standard so that means 24 volt isn't a problem and I've read the PC socket on the K7 and the K5 are protected but not that the hotshoe is though.
Better to play it safe i think then be sorry.
Stefan
K10D, K5
AF-540FGZ
digikid-tv
Posted 05/06/2011 - 19:18 Link
I do not own a K5 to test, and currently I have no intention of purchasing one.
If someone would care to loan me one I could test it in in a non damaging way, then we would know for sure.
John
karma mechanic
Posted 14/06/2011 - 10:16 Link
Just bringing this thread back for a moment...
I have a Vivitar 365 with a guide number of 48 (in metres). I've tried it with a slave fired by a small gun on the hot shoe and it can boil oceans. Since it comes with an on-camera sensor unit with variable zoom it is quite a sophisticated beast, it would be nice to use it via the K5 PC socket.
I've measured the voltage on the PC lead at 46 volts. That's too much for hot shoes, but I'm wondering whether the PC socket would be ok with that. Some PC arrangements are actually a mechanical switch in the shutter mechanism, certainly on older bodies.
Any ideas?
My own website is www.richardgaddphotography.com
Also on 500px
