using Da lenses with 2X `A` converter
Posted 10/03/2012 - 17:51 - Helpful Comment
As the manufacturers recommend minimum speeds for hand holding based on focal length x 1.5 I would do the sdame for entering focal length for the SR system. See how it works?
Posted 10/03/2012 - 18:50 - Helpful Comment
No!As the manufacturers recommend minimum speeds for hand holding based on focal length x 1.5 I would do the sdame for entering focal length for the SR system. See how it works?
That's not the same at all.
The focal length you tell the camera for setting the SR is the actual focal length of the lens - including the converter if you've used one (or something in the middle of the range if it's a zoom).
Focal length is always focal length! The camera already knows its sensor size, so you don't need to add a fudge factor to help it get its SR compensation right.
It's even in the manual to use the closest actual focal length!
The rule of thumb for minimum speed for handholding in the good old days was 1/focal length, and although that's very variable depending on the photographer, I have seen them recommend 1/(1.5 x focal length) for APS-C
But that's because of the enlargement of the shake you get when you enlarge the cropped angle of view to get the same final image size as you would have got with the equivalent lens on 35mm. Nothing to do with the SR setting at all.
For instance, 50mm lens on 35mm, rule-of-thumb for handholding 1/50.
50mm lens on APS-C, you get a smaller image on the sensor, which has the same angle of view as 75mm on 35mm.
If you want the same print size on APS-C, you have to enlarge your 50mm shot more than your 75mm shot needs on 35mm. But you enlarge the shake too, so the rule of thumb says 1/75.
Bottom line: actual focal length for SR setting.
If SR is off, then 1/1.5 x focal length for avoiding shake when handholding.
Posted 10/03/2012 - 20:53
Thanks, I understand the 1/1.5 bit and focal lenght bit, I was just out of focus as to when to apply it in SR, thanks for the help Guys.
Rob W.
Rob W.
Pentax super A 35mm.
Pentax K5 apsc
Pentax K1Mkii full format.
Pentax K5 apsc
On my K5 using my `A` Pentax 70-210 with an `A` Takumar 2X tele-converter I would set (for full zoom) focal length in the menu to 420, 400 in the scale in the absence of a 420 setting, (this is not a problem).
So when I use my Da 18-135 with the same `A` 2X tele-converter should I ( for full zoom) be entering 270mm or the 35mm conversion figure 405mm,app; ?
I don’t know if it is considered a problem either way, it’s just there is quite a difference in the focal length setting, any advice on this would be appreciated, does not seem to be listed (or that I can`t find it)
Rob W.
Pentax K5 apsc
