Using a flash with bowens studio lights
Posted 08/06/2009 - 13:55
Could you not use the Metz without the built in flash? It occurs to me that you are going to be using two manual heads so you would have to use the Metz on manual anyway. Best solution is one of those radio triggers from Hong Kong via eBay, mine only cost about £10 and is very good, to fire the Metz and then the other two can be triggerd by their photocells.
Posted 08/06/2009 - 16:35
An alternative would be to use an older TTL flash that has a tiltable head (AF400FTZ, AF500FTZ or similar) mounted on the hot shoe and pointed at the ceiling. If set to manual and low output, it would trigger the slaves with no pre-flash whilst contributing very little light to the scene. This assumes you have a ceiling to bounce from.
Radio triggers are cheap and my preferred option. If you buy the Phottix ones, make sure you get the MK-II versions where the receiver has a PC synch socket to wire your Bowens lights into. The ones I have (Original MK-I) don't have the synch socket.
Posted 09/06/2009 - 11:45
As Mannesty says, use an older flash of suitable trigger voltage in the hot shoe and have all other heads/flashes set as slaves.
bb2
bb2
K5, K20D, Bigma, Sigma EX 105, Sigma EX 10-20, Sigma EX 28-70 F2.8, Sigma Ex 1.4TC,
Pentax 135 F3.5, Pentax 30mm F2.8 , Pentax 50mm F1.7, Pentax 55mm F1.8,
Super Taks: 35mm F3.5, 50mm F1.4, 135mm F3.5, 200mm F4
Vivitar TX 200mm F3.5,Vivitar (Komine)135mm f2.8, Vivitar 2X TC, Vivitar T4 400mm F6.3
Tamron SP 35-80,80-210 F3.8, Helios 44M, Mir 1B 37mm F2.8, Jupiter 9 85mm F2, Chinon 28mm F2.8, 3M-5A 500mm F8 etc etc
I think the camera is Sending a pre flash which is triggering the Bowen's and then slightly later the Metz- any ideas?
K3, K7, 12 Pentax-17 pentax18-250, pentax50-135 2.8, tamron 16 - 70 2.8 18-55, pentaxc 50-200,pentax 50mm1.7,metz flash bowens 500 and studio stuff
