Under-exposure using flash with K-m
Posted 26/11/2010 - 17:13
I know the K-m flash sync speed is 1/180, so I usually set it to that (manually), set the aperture to what the flash expects, then use the Auto mode on the flash to set the exposure. No trouble so far. Mind you, it also seems to work fine if I use an old Pentax AF240Z with both camera and flash set to "P" - it generally shoots at around 1/45 and f8 or so depending on ISO setting.
Posted 26/11/2010 - 19:27
1/180 is actually the maximum sync speed so any speed longer than that can be used. Are both your cameras using the same ISO? Best not to leave that setting on auto IMO.
The different shutter speeds will make no difference unless you are using manual or P-TTL. Does your flash support P-TTL?
Posted 26/11/2010 - 20:53
Ahh, ok, that would explain a lot!
My knowledge of using flash came from a K1000 where you just set the shutter speed to "X" (aka 1/60 on that model). Oddly enough I couldn't find any reference to what speed equated to "X" on the K-m, but the Dimitrov site quoted 1/180 which seems ok with my Metz 45.
Posted 27/11/2010 - 13:07
Max sync speed so X isn't connected to the flash but with the speed the shutter moves, the faster it moves the faster the max sync speed can be.
Posted 27/11/2010 - 17:55
1/45 versus 1/180 should not make (much of) a difference with flash (if flash is the main source of light). The difference in shutter speeds is probably caused by a difference in p-ttl implementation in both cameras.
The difference in exposure is also caused by a difference in p-ttl implementation in both cameras (not necessarily the same difference).
Here,
there,
everywhere
Apart from this I am very happy with the flash, and my entry for the weekly competition was taken with this and a home-made soft box I knocked up yesterday from a plastic container, some tin-foil, and the translucent material the flash was wrapped in!
My Website
flickr
G+
Facebook
