tv mode on k20
Posted 11/04/2009 - 09:30
Are you sure your in Tv mode and not TAv??
What your describing is TAv mode.
EDIT: added Word.
EDIT: added Word.
Tel,
Posted 11/04/2009 - 09:33
Only when you have Auto EV Compensation (via Custom menu) turned on.
I expect it's the same with the K200D.
~Pete
Posted 11/04/2009 - 09:35
I bet Scott's K20D is in Tv mode but has Auto EV Compensation enabled. This adjusts the shutter speed when it would be out-of-range otherwise.
~Pete
Posted 11/04/2009 - 09:37
iceblinker wrote:
Yep! you might be right Pete.
I bet Scott's K20D is in Tv mode but has Auto EV Compensation enabled. This adjusts the shutter speed when it would be out-of-range otherwise.Are you sure your in Tv mode and not TAv??
Tel,
Posted 11/04/2009 - 09:52
thanks terry and iceblinker, bang on the nose, the k200d doesn,t have this option for the auto ev compensation on or off,
and thanks again guys,
just keep snapping,
nikon d300 + battery grip.
sigma 150-500mm apo dg hsm os
sigma 170-500mm apo dg
Posted 11/04/2009 - 10:14
Your Welcome.
Tel,
devon (honiton)
But on the k20 if set to 400s in dark light, it adjust the ss right down to what it thinks,
is this right,
