Trying to charge Optio E85, but camera got hot ?
Posted 05/11/2011 - 20:06 Link
Hi
We have 2 Kodac digital cameras one quite old and one current plus a Pentax Optio E85.
None of these have charger leads with them, so I have bought a multicharger and have some other charge leads from various other things.
Basically I'm trying to charge through the DC port, I've got the - C + thing correct I think but literally there isn't any lights coming on the cameras when I plug them in (and turn them off to charge). I am setting the charger to 5v.
any idea what I'm doing wrong?
Certainly the 2 most recent have never been charged before, I've read on them about using the wrong charger or wrong Volts which I think I did for the Pentax while trying different things out.
It got a little hot.
Any help would be great thanks.
Ash
Posted 05/11/2011 - 22:53 Link
It would be safer to use the correct charger.
Try www.srsmicrosystems.co.uk who will probably have the apprpriate Pentax charger, or may at least be able to order it for you.
Mannesty
Posted 05/11/2011 - 23:10 Link
Using the wrong charger, wrong voltage, or wrong polarity is potentially very dangerous.
Don't leave them charging unattended, and make sure your smoke alarms are working.
If you haven't destroyed the cameras already, get the correct charger.
Posted 06/11/2011 - 10:36 Link
How would I know if I've destroyed the camera ? I'm thinking maybe a new battery will do the trick ?
DoctorJeff
Posted 06/11/2011 - 11:10 Link
Do you even have manuals for any of the cameras?
Connecting anything that you don't know about to any electrical supply is a very quick way into trouble.
Geoff
X-5
istDS
K2000
P50.
Mannesty
Posted 06/11/2011 - 11:47 Link
Buy a new battery and the correct charger, then try it. You may be lucky.
Hyram
Posted 06/11/2011 - 16:12 Link
Charging lithium batteries with anything other than precisely the right charger is a good recipe for a house fire
Hyram
DoctorJeff
Posted 06/11/2011 - 17:40 Link
It is easy enough to find 3rd party batteries and chargers for your Optio.
I would say cheap as chips, but you have not been near my local chippy lately.
You asked:
and the short answer is not going to be very kind.
5v into a 3.7v battery? Ouch! And you were/are not even clear if you got the polarity right. Ouch(!) again.
Perhaps the most practical thing you could do is to use a multi-meter to check for continuity across the battery. Then if there is continuity, you can check the battery voltage. If that's OK, then you can put it back in the camera and check for function.
Just be prepared for a dead camera!
Geoff
X-5
istDS
K2000
P50.
