true macro!
Posted 15/04/2012 - 00:01
AFAIK anything up 1:2 is considered Macro; for example the legendary CZ Makro planar 100mm F2 ZK does 'only' 1:2
Posted 15/04/2012 - 08:02
I've always understood that macro means that a subject (e.g. 1 cm fly) will be that same size (or bigger) on the sensor or film. So that would mean 1:1
I however have never seen an 'official' definition. One old book that I have states that one enters macro territory at 1:10; I would definitely not consider that real macro.
wikipedia states:
The other point is that true macro lenses are / can be optimized for performance at the highest magnification
again wikipedia:
But does it actually matter what the definition is or what real macro is? Check the specs of the lens and if the magnification (at short distance) is good enough for the intended use, it does not matter if it's called macro or not
wikipedia states:
Macrophotography is close-up photography, usually of very small subjects. Classically a macrophotograph is one in which the size of the subject on the negative is greater than life size
again wikipedia:
although a macro lens may be optimized to provide its best performance at its highest magnification
Posted 15/04/2012 - 08:33
Usually 1:1, but because a 1:4 Zoom lens can be printed easily
at 1:1 (4x enlargement) that can be called a macro as well
Posted 15/04/2012 - 09:33
I thought it was as Sterretje says, same size image on the capture medium. I thought manufacturers altered that (unofficial but generally accepted) definiton so they could assign macro capabilities to compacts.
You can see some of my photos here if you are so inclined
Posted 15/04/2012 - 12:26
As somebody on the other forum often says: "printing 'macro' on a lens costs less ink than printing 'close-up'"
Adrian1
Member
