Tripod for Pentax K10D
Posted 17/11/2007 - 13:21
Slighty off topic here but why do you want to rotate the centre column to use it horizontally? What advantage does it give, and under what circumstances do you use it?
Just curious. I have removed the centre column from my tripod as it is tall enough without, and it is one less thing to introduce wobble.
I use that facility quite frequently when shooting photographs of flowers like this.
Posted 17/11/2007 - 16:48
Following a recommendation in one of the Photography mags I had a good look at a Manfrotto 190X PRO in Jessops a little while ago. Not sure what head to get yet but as soon as I have some spare cash I'll be getting one.
Posted 19/11/2007 - 11:02
MXV have a secondhand "new boxed" 190 at the moment with head for just under £100. Normally the legs would cost at least that much.
Kim
Kim
Posted 19/11/2007 - 11:21
190 legs are around £85 - £95, depending on whether you get the 'classic' or the 'ProB' type. But depending on the head you'd get with it, that looks like it may well be a bargain.
Dan
Dan
Posted 19/11/2007 - 11:34
It's the 115 head.
http://www.mxv.co.uk/tripods.asp?offset=50
Kim
Kim
Dan
Dan
Posted 04/12/2007 - 19:40
I'm new to this game (although my old camera is also a Pentax, a P30) and recently bought a Slik 700 DX tripod for £84.99. It's a bit 'industrial' and very heavy, but solid enough to mount a small telescope (6" reflector) and that's saying something.
El Dingo - K3-II and K10D
Copenhagen,
DK
Just curious. I have removed the center column from my tripod as it is tall enough without, and it is one less thing to introduce wobble.
I have shot a lot of leaves (some my daughter picked up outisde) this way.
I just find it's easy to rotate the center column - and gives some very good handling.
I took some good shots of some cards too. I placed them on our dinner table and needed the camera to point down . This way you can avoid hand held in low light conditions.
I like the tripod to be as flexible as possible.
