Tiger taken trough a viewing window
CoDa
Posted 21/11/2009 - 23:04 Link
Not sure of the grass on the sides, it has been heavily cropped.
[IMG]http://i941.photobucket.com/albums/ad254/weldingblues/Tiger2.jpg[/IMG]
C & C please, its is helping me lots
Colin
Edmund Burke (1729 – 1797)
mattcambs
Posted 21/11/2009 - 23:17 Link
It's a nice shot, but either your focus is slightly off or there is some slight movement blur. What was your focal length and shutter speed?
GX20; DA 17-70 F4; 18-55 kit; Ricoh 50mm F2; Vivitar 75-205mm F3.8
Bob and his Pentax
Posted 22/11/2009 - 00:22 Link
EXIF says K10D 300mm f9.5 ISO200 1/15sec your kit list suggests the Tamron 70-300
The rule of thumb for minimum shutter speed is 1/focal length; 1/300 to 1/15 is over 4 'stops' which is asking a lot of the K10D anti-shake.
I would suggest giving yourself a stop by increasing the ISO and another one and a half by opening up to f5.6 which would have given you a shutter speed of about 1/80 so only 2 stops off of the 1/focal length rule which would have given the anti-shake a better chance.
The larger f stop would have thrown the grass and background more out of focus too.
Given the objects (trees?)to the right and left I think I would have given this a portrait crop rather than a landscape shot.
Taking pictures at zoos can be a problem as there's always someone standing just where you want to be but half a step to the left would have cleared some of the grass from the tigers face too.
All that said I like the portrait of the tiger and you've captured a bit of it's character - it seems to be thinking "I wonder what that noisy toddler would taste like for lunch..."
Good luck
Bob
Edited by Bob and his Pentax: 22/11/2009 - 00:25
CoDa
Posted 22/11/2009 - 23:03 Link
I take it that I should have increased the ISO to 400?
What is anybody's recommendation for a general ISO setting, as this is all new to me this type of information is of great help.
Colin
Colin
George Lazarette
Posted 22/11/2009 - 23:24 Link
Basically, the lower the ISO the better the picture quality. However, 200 ISO is pretty much indistinguishable from 100, and 400 isn't much worse.
Try to make that a maximum, but better to use 800 or 1600 and get a sharp picture than use 400 and get one that's fuzzy.
With a long lens, you'll usually be talking about using higher ISO, especially in the UK.
Don't be afraid to use a long lens wide-open. That'll help avoid camera shake and let you use a lower ISO. Of course, some lenses are quite soft wide-open, especially zooms, and I can't speak for yours. Take some test shots and see what works.
