The real problem?
Posted 19/08/2010 - 20:04
You aren't comparing like with like. Those are bog-standard primes, not top-quality ones.
There's plenty of affordable (new) primes for Pentax, e.g. DA21/DA40/FA50...
If you wanted to find something comparable to the FA77, the nearest Nikon lens is the 85mm 1.4 - which is (drum roll) £899, so actually £150 more (SRS new prices).
So - your question should be - 1 super lens OR 3 cheap ones. Brand is irrelevant.
Posted 19/08/2010 - 20:22
The Photozone review of the FA77 said that it is - in IQ - essentially comparable to the Nikon 85 f1.8 - that was the primary comparison I was trying to make (ie that the price difference between those two lenses is so great you can get another two admittedly cheap-and-cheerful primes and still have money left over)
Posted 19/08/2010 - 23:29
But then, if you have a Pentax body to affix aforementioned lenses, you wouldn't be daft enough to buy the Nikon prime(s), would you?
But if you have a Nikon body, I believe you can fit a Pentax lens to it.
So it's a no-brainer, Nikon D3X + Pentax FA 77mm Ltd + adapter it is then.
Posted 20/08/2010 - 01:10
Nikon has a longer registration distance than Pentax, so your dastardly plan wouldn't work (okay okay I suppose it could be done but without infinity focus).
Tim
Posted 20/08/2010 - 10:57
You can get a PK to Nikon converter. It uses an additional lens inside the converter.
You can also get Nikon to Pentax.
Posted 20/08/2010 - 12:47
flossie wrote:
I think its Canons you can fit Pentax lenses to, not Nikons...
Yes, and IIRC only the APS-C Canons (the mirror gets caught on part of the back of the lens on FF models - not that I'd ever be buying one anyway!)
Posted 20/08/2010 - 12:55
There is quite a little cottage industry over on MFLenses where people shave a few millimeters off the bottom of the mirrors of full frame Canon 5Ds so it wont foul the back of non-Canon lenses.
Tim
Glasgow
Don't worry, this isn't an anti-FA77 trolling thread: it is a lovely lens, definitely one of the best AF lenses ever made. But is it better than owning all of the following and having £140 left over?
*Nikon 35 f1.8 (£169)
*Nikon 50 f1.8 (£116)
*Nikon 85 f1.8 (£330)
Now I know the FA77 has truly fabulous build quality, and is compact - but are there enough people for whom compactness and finish are important enough to pay the current Pentax prices? As I say, I'm not knocking the FA77 but in image quality is the Nikon likely to be less than half as good?
Of course Pentax has other advantages - ergonomic bodies, weather sealing [though not with the Limited primes of course], and build quality. But a nice body which you can't afford lenses for is a bit pointless, no?
