the cheaper Pentax 540 battery pack...
strumstrum
Posted 23/04/2013 - 15:52 Link
...the one that takes 8aa's. anybody have/used one? what are your thoughts?
thinking it might be worth a punt, worth a gamble at that price..?!?!?
smudge
Posted 23/04/2013 - 16:04 - Helpful Comment Link
I have 3 of them - one for each 540. Not a lot to say really. They do what they are supposed to do. The only issues I have had are that I had to buy 4 to get 3 that worked - so quality control may be a bit hit or miss; also the on/off rocker switch is not recessed so it is quite easy to get knocked to the 'on' position in your bag.
Regards, Philip
Edited by smudge: 23/04/2013 - 16:06
bettyswolloks
Posted 23/04/2013 - 16:38 - Helpful Comment Link
I have one, it does what it says on the tin. The build quality is good enough and the nylon bag is equally good. When the flash is set up to use it for recharging the flash it increases the flash recycle time significantly.
strumstrum
Posted 23/04/2013 - 17:17 Link
super have ordered one, well worth the punt I reckon.. I am generally pleasantly surprised when ever I buy a 3rd party accessory.
Mannesty
Posted 23/04/2013 - 18:06 Link
I have one and ordered another for my other 540.
Works well and handy that you can bolt it to the tripod mount.
Mannesty
Posted 23/04/2013 - 18:09 Link
bettyswolloks wrote:
. . . for recharging the flash it increases the flash recycle time significantly.
Err, I think you meant it decreases the recycle time . . .
Mine recycles in about 2 secs after a 100% discharge. You still need batteries in the flash though.
What it means for me is that I can spend 2+ hours on the race track on winter evenings without needing to replace the batteries in the flash half way through the evening. Result.
bettyswolloks
Posted 23/04/2013 - 20:06 Link
That's the one!!
strumstrum
Posted 28/04/2013 - 10:17 Link
very pleased with my purchased, just the size that stunned me, I had pictured something a little bigger than 8aa's..
still it did its job and performed flawlessly so well worth the money.
Mannesty
Posted 28/04/2013 - 10:23 Link
The Pentax power packs are bigger because they use C cells but for me, the use of AA's is more convenient.
strumstrum
Posted 28/04/2013 - 10:27 Link
I didn't even consider the Pentax one because of them using C's, cost was also a factor but battery type came first.
johnwhit
Posted 28/04/2013 - 10:47 Link
Are we talking about this one:
link
TIA,
John
PPG link
In LBA hiatus.
Mannesty
Posted 28/04/2013 - 10:50 Link
link
TIA,
John
Yes, that's the one I have, and another on its way.
johnwhit
Posted 28/04/2013 - 11:00 Link
Wow that's a big saving on the genuine TR3 and oh so handy, always wanted an external pack but couldn't justify the expense, thanks all.
John
PPG link
In LBA hiatus.
