Teleconverter problem
Posted 19/01/2009 - 21:04
I can't imagine it'd cause any problems but I'm not intimate with that TC - are you sure it's meant to have a spring? Sounds like it was designed to rely on the lens for its return...
If you have a photo or two a diagnosis would be easier.
Joining the Q
Posted 20/01/2009 - 06:06
Thanks for that,I have never seen a TC with floppy actuator and assumed it was a fault.I will give it a go.Many thanks.
Posted 20/01/2009 - 20:10
Ok ,Ricoh pin removed and a nightmare had reassembling.I put the TC on an A lens and then attached to camera body.The camera does not recognise aperture value,it acts like an M lens.Am I missing something obvious?
Thanks, mm
Thanks, mm
Posted 20/01/2009 - 21:21
All pins good on second reassembly I just tried scraping paint off the mount as I think I read somewhere that was a fix for something.It didn't work but I had nothing to lose.It's probably time to give up now,Idont want to ruin other bits in a forlorn attempt to make an old part work.I do not want pride and stubborness to bite me.
Thanks for your help, mm
South London
Many thanks, mm
