Tele zoom for K10
Posted 05/02/2007 - 15:34
Have you also considered the SMC Pentax-DA 50-200mm, which is an ultra-compact and superb lens?
Posted 05/02/2007 - 16:38
I would go for the FA 80-320mm as I have had some excellent results with mine. I think you would be disappointed, as I was, with the build quality of the cheaper FAJ 75-300mm.
Even if you did get the FA 80-320mm, don't get rid of your excellent 300mm unless you can replace it with an SMCP-A version.
I have no knowledge of the 100-300mm.
Posted 05/02/2007 - 18:07
I second JR's suggestion. The 50-200 is very good, and you already have the Takumar for when you need 300mm.
Posted 05/02/2007 - 20:32
I havn't used one either but Stan Halpin's site seems to suggest the 80-320 is better.I have no knowledge of the 100-300mm.
the 80-320 and 50-200 are both very good lenses for the money.
The 50-200 has manual focus override, a smoother zoom ring and a non-rotating front element. It is also smaller and lighter.
The 80-320 obviously has a little more reach at the long end, at 200mm it's faster (both are 4.5-5.6 lenses but the 80-320 is still 4.5 at 200mm) and its 8 aperture blades make for nice smooth out of focus regions. May or may not bother you but the 80-320 is also compatible with every K mount body (I've used mine on a K1000 once or twice) where the 50-200 is digital only.
Posted 05/02/2007 - 21:06
Thanks for all the input friends!
Moongoose hit the nail´s head when bringing the analog issue up. I still have my KM and I´d like to be able to use my tele zoom "to be" on the old girl as well. In fact, I have quite a few SMC lenses but none of them are D-lenses.
As for the SMC Takumar, its a great lens. But a bit too tricky to shoot birds and stuff with, sa its a manual focusing lens that requires stop down metering.
Anybody who´s selling an F or FA 300* lens?......
// Mats
// Mats
Posted 05/02/2007 - 21:10
in that case you don't want the FAJ 75-300 either, it has no aperture ring so wont work in any useful fashion with your KM.
As I said the 80-320 is very happy on a K1000 so should work wonders on a KM. It's focus ring is rather loose by comparison to MF lenses, but it's useable.
Posted 05/02/2007 - 21:34
Yes, I just figured out that the "J" lenses doesn´t have an aperture ring. So, that seems to leave me with the 80-320.in that case you don't want the FAJ 75-300 either, it has no aperture ring so wont work in any useful fashion with your KM.
And now.......off to eBay....
Thanks again guys!
// Mats
Posted 06/02/2007 - 14:51
Posted 06/02/2007 - 21:05
20 years
Sweden
FA 100-300
FA 80-320
FA J 75-300
Which one would you gor for? Or should I stick with my SMC Takumar 300/4?
// Mats
