Tamron sp AF 90mm 2.5 Macro
Clarky
Posted 25/08/2007 - 02:55 Link
Good day all
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=290150343074&ssPageName=STRK:MEWN:IT&ih=019
I have just purchased this lens off e-bay and would like to know if i may have been a bit rash or made the right move. I bid on it on a whim and didnt know anything about it.
After some research of which there is little info i could find on the 52mm. I have found it is not the adaptall 2 i assumed it was but a fixed mount (pentax) unlike the older version 49mm and the later version 55mm. I was going to get the SP 2x 01F tele convertor to get it down to 1.1 from 1.2 which the older version and i ASSUMED the 52mm version was but that would not be compatible with the fixed mount So i guess i just need an ordinary TC or an extension tube : : Or would i need a dedicated TC or extension tube.
I am very confused now and any help on this would be greatly appreciated.
Camera:|K-7|
niblue
Posted 25/08/2007 - 09:28 Link
I was actually tracking that item but the reason I didn't bid was because I couldn't find any information on the AF F2.5 version.
They've got a good reputation for macro lenses though so I'd expect it'll perform well.
Clarky
Posted 25/08/2007 - 09:59 Link
I dont think it will be a dud. But as you say no info on it at all.
I will have to wait until it arrives and see if it is as decribed. It may not even be a Tamron
Camera:|K-7|
Posted 25/08/2007 - 10:53 Link
I did have a Tamron 90mm f2.5 Macro at one point. It was manual focus.
The only problem was that compared to the pentax lenses it was so enormous and so heavy. Quite out of context with all my other lenses, so I sold it on.
In terms of performance though it has an excellent reputation. I know a professional who for a long time bought a new one every couple of years. He basically wore them out. He never had to replace his Nikon or Olympus lenses though, so I suppose that tells us something.
niblue
Posted 25/08/2007 - 11:04 Link
Perhaps it tells us that the Tamron was so much better than his Nikon on Olympus lenses that he never used them...
Clarky
Posted 25/08/2007 - 11:07 Link
You took the words right out of my mouth Niblue
Camera:|K-7|
Posted 25/08/2007 - 11:48 Link
The obvious conclusion.
fatspider
Posted 25/08/2007 - 16:25 Link
You have made a good choice Clarky, I have the excact same lens and I rate the optics as good as any of my Pentax glass, this is obviously not going to give you 1:1 macro so invest in a set of extension tubes and get snapping.
I think I paid around £95 used from a dealer about three or four years ago, so your price doesn't seem too bad.
I'll see if I can dig some links to shots from it and send you the links.
Sorry quick Edit.......your lens is obviously the KAF mount so fully compatable with the K10D, extension tubes are available as simply K mount (no electrical contacts) KA mount with the contacts and full KAF with AF facility, I would suggest you go for a set of KA as auto focus tends to be a bit iffy at such close quarters.
My PPG link
My Flckr link
Clarky
Posted 25/08/2007 - 23:22 Link
I have already been looking for a set of extension tubes. But i ask you this, I need one that is 45mm to get the magnification to 1.1 so i am assuming it wont hurt if i only put a 36mm in there instead. After all there is no optics in those things. (or can i buy a 45mm)
What if i use a tele plus Macro extender mc7 would that give me the same result :
Camera:|K-7|
fatspider
Posted 26/08/2007 - 14:07 Link
Extension tubes, to the best of my knowledge only come in sets of three, lengths do vary slightly from make to make, individual tubes are probably available but will no doubt be costly, my set are Jessops own brand "KA" mount tubes 13, 21 and 31mm. there is nothing to stop you using any combination of one or more tubes to get the desired magnification ie a 31 and 21mm tubes will give you as near as possible the 45mm your after.
Contrary to popular belief extension tubes can have an effect on image quality, despite the fact tubes have no glass you have to bear in mind that you will be moving the lens optics away from the focal plane (film or sensor) that the lens was designed to produce the image onto, I hope thats the right explanation But dont worry about it, its not something your going to notice.
EDIT: heres a link to some macro work with the Tamron http://www.birdforum.net/gallery/showgallery.php/cat/500/ppuser/48441
My PPG link
My Flckr link
