Tamron Adaptall Lenses
bforbes
Posted 20/01/2013 - 16:37 Link
I have a number of Adaptall 2 lenses so know what functions are available with the pk and pka adapters. However I'm not sure what you get with the Adaptall lenses ("1" I suppose rather than Adapt-A-Matic)
For instance can you still use the green button or do you have to stop the lens down manually after focusing wide open?
sorted78
Posted 20/01/2013 - 22:27 - Helpful Comment Link
The main mechanical difference between Adaptall '1' and Adaptall-2 mounts is that the Adaptall-2 lenses have the functionality to indicate their maximum aperture to Adaptall-2 mounts, whereas Apatall '1' lenses do not.
As I understand it, this doesn't affect us Pentax users, so we can use Adaptall '1' and 2 lenses and mounts completely interchangeably. I've happily used my Adaptall-2 PK/A mount with Adaptall '1' lenses.
The Adaptall '1' series had a PK mount only (labelled PK/M) which was equivalent to a Pentax M lens (green button metering required). The PK/A mount was introduced in the Adaptall-2 range and gave functionality equivalent to a Pentax A series lens allowing the control of aperture from the camera body.
I believe that for more 'complex' mounts, like Canon FD, it is only possible to use Adaptall-2 mounts correctly with Adaptall-2 lenses.
bforbes
Posted 20/01/2013 - 23:30 Link
Thanks. I was confused by people advertising PK/M mounts as Adaptall 2. Leading me think Adaptall was something different again, with less function than you get with PK/M mounts.
petrochemist
Posted 21/01/2013 - 10:48 Link
The majority of Adaptall-2 adapters for pentax are PK mounts - only giving M type functionality. Changing the adapter to the more expensive/rare PKA version enables the extra functions. I suspect most of the ads you refer to include the PK mount, but as they can be changed to PKA mount (or numerous other mounts) they have more function than a fixed PK.
bforbes
Posted 21/01/2013 - 11:03 Link
I have both PK/M and PK/A mounts and was aware of the extra functions. It seems it's more correct to call the PK/M mount - Adaptall and the PK/A mount - Adaptall 2. Or do you think there is a separate "Adaptall 1" mount?
Again not counting the Adapt-A-Matic system.
Algernon
Posted 21/01/2013 - 11:40 Link
This one on ebay, doesn't say Adaptall 2 on the main name
just Adaptall Custom Mount, but it does say it's suitable
for Adaptall and Adaptall 2 so it must have come out after
the release of Adaptall 2 lenses and because it isn't called 2
I would expect that it's the same as the original.
I don't really trust the Adaptall 2 PKA mount adjusting
the aperture properly from the body, so I don't mind
using the KM mount.
Edited by Algernon: 21/01/2013 - 11:40
gwing
Posted 21/01/2013 - 12:53 Link
I think it is more the case that the Tamron *lenses* adaptall 1 or adaptall 2. Both Adaptall 1 and 2 lenses can use either PK or PK/A adapters and I believe the simpler PK adapter continued to be produced long after the Adaptall 2 lenses appeared.
gwing
Posted 21/01/2013 - 13:02 Link
using the KM mount.
In which case I'd be happy to offer a swap of my original PK mount for your PK/A one
Edited by gwing: 21/01/2013 - 13:04
Algernon
Posted 21/01/2013 - 13:04 Link
The PK/A mount is a status symbol
