Tamron 75-250mm 104a
Posted 16/10/2007 - 00:18
You need to change the setting in the camera to allow use of the aperture ring. Go too custom setting and scroll through to the last page and you will see USING APERTURE RING change this setting too permitted and you will be sweet
Camera:|K-7|
Posted 16/10/2007 - 00:35
Oooh! Thankyou. That's brilliant.
Thanks a lot
Thanks a lot
Posted 16/10/2007 - 00:57
Apologies for the double post.
Is there an adapter or something similar I can buy to allow me to use the other lenses?
I've got (all are tamron)
SP 2X Tele-Converter
SP 35-80mm F/2.8-3.8
SP 17mm F/3.5
SP 24-48mm F/3.5-3.8
There's also Nikon Dw-3 and Dw-4 flash units...
I'm not sure what brand the lenses were for originally. I'm guessing nikon as most of the other stuff is nikon, but I could be wrong.
Can anyone shed some light?
SP 17mm F/3.5
Posted 16/10/2007 - 01:51
Do they have the adaptall 2 adapter mount :
If they do then they should be detachable and you will need to buy a pentax adptall 2 mount.
I just checked the links you have on the lenses and they are definitly Adaptall 2. Now i don't know if the lenses you have also have the adaptall 2 mount attached or they have been removed.
So anyway you will have to get the pentax mount too suit.
Here is one on E-bay
http://cgi.ebay.com.au/TAMRON-ADAPTALL-2-MOUNT-PENTAX-K-RICOH-XR-COSINA_W0QQitemZ230181227992QQihZ013QQcategoryZ30059QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You can always remove the adapter off the 75-250 and fit it too the other four lenses
Camera:|K-7|
Posted 16/10/2007 - 17:40
Aha!
I didn't realise the 75-200 had an adapter on the end of it!
I've just taken it off, I'm gonna try the others out now.
Thank you
Thank you
Most of them are nikon lenses, but there's a tamron one (the one in the title) which fits my camera.
It specifically states it's for pentax k camera, and it attaches fine, but when I try and take a picture it refuses to focus properly. I can play around and get the image into focus, but the aperture seems all wrong as it's a telephoto lens and the foreground is really blurry, rather than the other way around...
When I look through the viewfinder, I can see "F --" flashing, as well as on the LCD display on the top of the camera.
If anyone could offer any advice I'd be most grateful... I'd really like to be able to use it. Would I need to buy an adapter or something, or am I just missing something glaringly obvious?
Thanks a lot in advance.
