studio flash
BMurray
Posted 03/03/2012 - 07:46 Link
I have been searching for a simple flash set up so i can enhance my learning curve and do some 'studio' work, i've noticed on youtube and other sites that a lot of people seem to be using simple flash guns (they look like the same ones you would attach to the cameras hotshoe)with an optional soft box. I am aware that a 'good' studio flash would cost hundreds but is the smaller flash gun set up an acceptable alternative or is it the case that only a professional would know how to use this set up?
B Murray
Chrism8
Posted 03/03/2012 - 08:01 Link
I've been using a set of 3 normal studio lights 250w c/w softboxes, umbrella's, stands and triggers for £250 delivered to the UK, for 3+ years at least monthly and very impressed.
OK, there not professional quality, but there pretty good, check out " Link Delight " on fleabay or google them.
Chris
pentaxian450
Posted 03/03/2012 - 10:22 Link
The cobra flashes with soft boxes will deliver softer shadows than the flash alone, but they don't cover an area large enough for a "full body", and the soft boxes absorbs quite a bit of power.
That said, I regularly use them when I need portability over anything else, and they do an acceptable job.
To cover a larger area, like a standing person, a translucent umbrella is a better alternative, but you need a fairly powerfull flash. To me, the AF 360 FGZ is not powerful enough, but the AF 540 FGZ is.
Don
Posted 03/03/2012 - 16:25 Link
if you want cheap, I'd say go with simple clamp on styled incandescent light available from the hardware store for under $15.00 and try out some incandescent/cfl/halogen/led bulbs... but some gels and parchment paper for color / diffusion and make your self some "paintcan" lightstands and get good with your lighting skills, becuase everything you learn from that bit of kit, will be directly benificial when you start working with flash, and there are cheap slave flash units that screw into standard light sockets so your "Ultra cheap" lights and stands will still be usable with your slaved flashes... then move up to more expensive gear...
Edited by Don: 03/03/2012 - 16:26
Mannesty
Posted 03/03/2012 - 16:53 Link
I'm no studio flash expert, but I've gone through the same decision process recently.
I opted for:-
2 x Konig light stands , about £12.00 each.
2 x Kaavie 40" Umbrellas, about £23 each.
3 x Flash/Umbrella bracket, about £14 each.
To these, I attach my 2 x AF540FGZ flashes as my main lights and 1 x AF500FTZ flash for the background. I trigger them with Seculine TwinLink radio triggers.
I opted for the Seculine radio products because Pocket Wizards are way out of my price range, but you might consider Cactus 5 triggers as a cheaper option. They are well regarded but were not available when I went through this exercise.
If you choose to use umbrellas, go large, 40" minimum. You'll soon discover that the smaller umbrellas supplied as standard with some kits don't have a wide enough spread.
As for flashes, you don't need top of the range, all singing all dancing kit, but they will need to be reasonably powerful. AF500FTZ's can be had quite cheaply nowadays, but other flashes having GN's of 50+ are also available at reasonable prices.
Happy hunting.
wvbarnes
Posted 03/03/2012 - 19:31 Link
Flash umbrellas etc very very cheap on the ubiquitous 7 Day Shop just now. I've no idea what to buy mind you as I'm new to all this stuff! 40 inch translucent umbrella £5.79 for example!
BMurray
Posted 03/03/2012 - 21:29 Link
Don and Peter, that sounds very useful, thanks. Bill, i'm with you It's all a bit harder than I anticipated but im determined to see it through, I've already got 3 bookings from firnds of friends for various events. arg!!!
B Murray
Mannesty
Posted 04/03/2012 - 12:57 Link
I forgot to add that you'll probably need a flash meter as well to get correct exposures. Have a look at the Sekonic range. I use the L-358.
BMurray
Posted 07/03/2012 - 06:43 Link
does anyone have an opinion on this kit? its my friends brother has them in his garage and said i could borrow them to try them out with a view to buying them:
2 x courtenay 4000 monoblocks with stands and brollies
2 x courtenay 2000 monoblocks with stands and brollies
1 x lastolite background support system with 'curtain' background
1 x sekonic L0308B flash/ambient light meter with accessories
sundry lighting accessories inc. snoots, honeycombs, reflectors.
i would be grateful if anyone could tell me if there is a wireless trigger compatible with this and if its compatible with a pentax k-r.
B Murray
gartmore
Posted 07/03/2012 - 08:01 Link
Sounds excellent,you dont need four heads to begin with. One or two and a reflector is enough to start learning on.
Mannesty
Posted 07/03/2012 - 08:10 Link
I think most, if not all wireless triggers are generic, that is, they all work with everything (in theory anyway). With some, you may not get full synch shutter speed.
You'll not get P-TTL or TTL control with them because they use only the centre contact of your camera/flash, so you'll need to learn full manual control of your camera and flash setup. The flash meter will help you a lot.
At the top end, you have Pocket wizards preferred by many professionals, but they are very expensive. I use Seculine Twinlink products which have the benefit of both IR and radio triggering and work up to 100 metres outdoors. A popular option is the Cactus V5 system which I believe can also be configured as a wireless remote shutter.
I had a bad experience with the cheaper PT-04 type and cannot recommend them, but I know others have had good experiences with them. I had one transmitter and 3 receivers. Within 6 months, two of the receivers died and I switched to Seculine which have never misfired or let me down.
Edited by Mannesty: 07/03/2012 - 08:12
BMurray
Posted 07/03/2012 - 21:43 Link
oh, i think i've found it on ebay 180W STUDIO FLASH LIGHT KIT + STAND + UMBRELLA+ TRIGGER http://www.ebay.co.uk/itm/200702438532 this looks like it would do me for starting off with.
B Murray
usuqa
Posted 17/03/2012 - 10:47 Link
It might be a bit late but check out http://www.lencarta.com/lighting-store/flash-heads
I got there 3 smart flash setup around 1-2 years ago now and I have had nothing but a great experience with them.
1sec refresh rate at 200w/s(full) power, full down to 1/16 (4 stops of control) as well as a 150watt modelling lamp.
