stuck M42 lens
Posted 08/10/2005 - 15:50
There is a certain amout of supposition here but We will have to stsrt somewhere. I rather suspect that when you took the Vivitar of something came loose. Is your 1.4 an SMC version or a Super Tak. If it is the former, check to see if it is fully on the mount. If not the reason it is set on auto is that the lock pin on the back hasn't been pushed fully home so the lens thinks it is on an SPF or ES with full aperture metering. If so then the Vivitar did leave something which has blocked the threads and caused them to lock. Without site of the camera, it would be difficult to advise fully but if you can send me a decent JPG of the problem, I may be able to offer more help.
Kim
Kim
Posted 08/10/2005 - 16:15
I'll see what I can do about rigging mirrors up to mirrors but I don't know if I'll be able to send a photo. I'm not sure there's much to see anyhow, it all looks normal except the auto/manual ring is, I think, neeearly all the way at auto (but maybe stuck not quite there, I can see part of the "m" in the word manual. When I turn in one direction the whole lens+mount moves a bit but not like it's screwing tighter or unscrewing. Otherwise, I can't get the adapter off by pushing the release on the camera (because of the springy thing in the adapter, know what I mean?). I'll pm you my phone number and if possible could you call and I'll call right back so it's "my dime" for the phone call?
Anyway, thanks for any info!
dave
dave
21 years
Thanks again
