Strange focusing
Posted 06/04/2010 - 22:53
are you using split prism focusing screen?
To be honest, without that I couldn't MF anything but the 400/5.6 I used to own.
Even my Sigma 105/2.8 gave a lot of trouble!
With split prism screen it's much easier. I still miss some shots, but mostly they are fine...
Posted 07/04/2010 - 00:34
Just the stock screen.
As I said, the focus scale was far from the 10m (give or take) that the roof is...
Posted 07/04/2010 - 07:03
You may be experiencing this:
https://www.pentaxuser.com/forum/topic/k-7-shims-18721
I replaced my .40mm shim in my K-7 with a .20mm shim and the manual focus is spot on, now.
Cameras:K-7/K20D/*ist D/K10D
Lenses:DA14 f2.8, A16 f2.8, FA20 f2.8, FA31 f1.8, DA35 f2.8 macro, FA43 f1.9, FA50 f1.4, A50 f1.4, A50 f1.2, FA50 f2.8 macro, DA*55 f1.4, FA77 f1.8, DFA100 f2.8 macro, A100 f2.8, DA*300 f4, FA*300 f4.5, DA10-17 FE, DA12-24 f4, DA*16-50 f2.8, DA17-70 f4, FA*28-70 f2.8, DA*50-135 f2.8, DA*60-250 f4, FA*80-200 f2.8.
Flashes:AF540FGZ, AF360FGZ
Posted 07/04/2010 - 09:11
But Lance, if this was the case, and we assume that is provoking the visible differences in focusing, would they be very noticeable at all focusing distances?
I know I have front focusing issues, allways have had.
I used a chinese split prism for a bit, but that also had problems and focus was not spot on.
I have had shots were I focus is off or nothing is in focus, but nothing like this.
I've also had very different problems with FF. I remember for example the Tammy 24-135mm was almost spot on, while the kit lens was way off (45 angle thingy...)
Posted 07/04/2010 - 11:04
If you're using auto focus detection, check which focus point you have selected in-camera I suspect it's not centre
Posted 07/04/2010 - 11:34
It was in the centre focus point.
I'll try a battery of tests to see if I can obtain additional data that may clear up this mystery.
Posted 07/04/2010 - 23:13
As far as I am aware, the FF/BF issue only affects AF lenses when using AF-S/AF-C focussing, not manual.I know I have front focusing issues, allways have had.
Other than that I can't offer any explanation for your problem. Do you have other lenses you can try at infinity?
Posted 08/04/2010 - 00:32
With older manual lenses the focus point defaults to centre spot, you cannot choose anything else.If you're using auto focus detection, check which focus point you have selected in-camera I suspect it's not centre
K.
Posted 08/04/2010 - 02:05
There is a shim that adjusts the focus screen accuracy, covered here in this thread:edumad wrote:
It is one thing to be able to get AF accuracy via the AF adjustment feature, but another to have the actual focus screen reliably and accurately focus when manually focusing (and for that matter have accurate AF confirmation via the focus screen) and hence the shim adjustments between the focus screen and the pentaprism.
I removed the .40mm factory shim and put in a .20mm shim and this corrected my slight manual focus error.
Posted 08/04/2010 - 10:55
I've had problems with FF with manual lenses. Maybe its the automatic focus detection thats wrong. But I remember using a split prism chinese screen with a 50mm f1.7 and that also was not accurate (but maybe it was the screen's fault).
Posted 08/04/2010 - 12:03
edumad wrote:
The split-prism screen would have no effect on the focus indicator (hex/beep).
I've had problems with FF with manual lenses. Maybe its the automatic focus detection thats wrong. But I remember using a split prism chinese screen with a 50mm f1.7 and that also was not accurate (but maybe it was the screen's fault).edumad wrote:
Apparently.
Apparently.
Posted 08/04/2010 - 13:42
Sounds like you need to change your shims as Lance suggests.
K.
K.
Posted 08/04/2010 - 14:16
Well the sensor (photo) is the deciding factor here because you can't move that.
1) use AF and take a photo - you can then see if you need to adjust the AF or not
2) use manual focus (split-prism screen) and take a photo - if the DOF is off you know you need to use shims to adjust that.
ps. it can easily be that both are wrong, also remember that AF sensor is affected by the colour of light indoors it behaves slightly differntly then outdoors
Portugal
I was doing a side-by-side comparison between the Tamron A2 135mm F2.5 and Pentax Tak bayonet 135mm F2.5, because I need to trim my collection and want to make a decision.
I noticed this strange behaviour while focusing both lenses...
I try to focus on the far distance building with the little tower (upper right corner in these heavy crops).
Tamron Adaptal-2 135mm F2.5, ISO100, F4, 1/320
SMC Tak bayonet 135mm F2.5, ISO100, F4, 1/400
Both show the rooftop (much closer) in focus while the point of focus (circa infinity) is not in focus, neither is the space between (or the space between roof and camera btw).
I checked, I didn't mix shots. I focused using the automatic focus detection, but to my eyes it should be in focus or close. The focus scale does not lie though, the focus was hitting the edge on both. Going back does not improve focus.
Funny thing is, the roof top is in better focus than when I tried to focus the roof (not a bit, noticeable...).
What the heck is going on?
On a related note, my opinion, based on these copies and the few shots taken is that.
The SMC tak bayonette is far less of a dog than many say. But is it noticeable softer than the SMC-M F3.5 at all apertures (at least F3.5-8 ).
The Tak-bayonette is sharper than the Tamron at F2.5, but this seems to change at higher apertures. However the Tak-bayonette showed PF which I did not see for the Tamron under the same conditions. This is probably a result of the tak-bayonete being a budget lens with poor coatings?
