Still plenty out there
Posted 12/08/2010 - 15:30
You can probably kill the growth completely, assuming you can get to it. I find vinegar on a cotton bud works very well for neutralising and removing it.
Prime lenses are the simplest to work on, but you'll need a lens spanner to do it properly.
Now, if anyone knows how to get the plastic light shield thingy off the back of an SMCP 28-50mm zoom? I got most of the fungus out but couldn't remove the rear element group to finish the job.
Posted 12/08/2010 - 16:17
Thanks Matt
Tony
Tony
Posted 12/08/2010 - 18:53
Update - I managed to get the back end of the 28-50mm apart after some more unbolting, it now has some dust but no fungus! Even more amazingly it went back together ok and I think it works.
If the Takumar 50mm f1.4 is anything like the later SMC-P 55mm f1.8 or the M 50mm f1.7 then they're pretty simple to work on. I've rescued a couple of fungus-infested 50mm f2s, on both of them the infection was on the front of the forward element of the rear group, so all I had to do was unscrew the finishing ring, unscrew the front element group, swab the fungus off, polish clean, and reassemble with as little dust as possible.
Posted 12/08/2010 - 20:20
My job for next week then !
Thanks again
Tony
Thanks again
Tony
Wirral - Cheshire. IQ 153 Chest Large
Just taken delivery of a Spotmatic with original strap,ERC,clip on flash mount(sprung not slide),3 lightmeters in leather cases,and a 1.4 50mm lens ( with some fungus )and front cap.
Pretty good for £32 plus postage - first impressions very favourable - a couple of test shots at F8 on the *istD show no obvious signs of deterioration in picture quality.I shall follow earlier posts and keep the lens in the "sunlight" in order to minimise growth.
Keep shooting
Tony
