Start point and finish point using the e-dial, K-r.
Posted 30/11/2011 - 15:04
The e-dials do not have limits. They rotate forever
The effective start and finish point is down to what you are controlling
For example, if you are controlling Av with the e-dial then it will go between the maximum and minimum aperture values of your attached lens - e.g. f/4 to f/22, or f/2.8 to f/32.
If you are controlling Tv, then it's the shutter speed limits of the camera.
The intervals are usually half stops. But you can change that to one-third-stops in the custom menu.
Hope that helps!
Hope that helps!
Posted 01/12/2011 - 00:46
Thanks very much Matt. Isn't it easy when someone shows you the light?
Merseyside
