Stars
coker
Posted 07/03/2011 - 22:03 Link
Nice & clear tonight!
Orion
[IMG]http://i1021.photobucket.com/albums/af340/rogerhlane/Stars4001Orion_filtered.jpg[/IMG]
The Plough
[IMG]http://i1021.photobucket.com/albums/af340/rogerhlane/Stars4002Ploughcolour_filtered.jpg[/IMG]
Both images:
K7, 18-55 @ 18.
ISO 800, f3.5.
Orion 15.35 secs.,
The plough 14.61secs.
Coker
Father Ted
Posted 07/03/2011 - 22:07 Link
18mm you say? How much were they cropped?
I particularly like that you can make out some nebulosity in Orion. And you exposure times are just enough to capture the dimmer stars without showing too much motion.
Well done!
coker
Posted 07/03/2011 - 22:18 Link
Thanks, Ted.
The Plough wasn't cropped at all.
Orion is about 25% of the original size.
I did set the lens to 18mm when I started & that's what the exif states.
But I've looked & it's set @ about 30.....?
Can you tell from the images what's what, or is the exif always right?
Roger.
Edited by coker: 07/03/2011 - 22:19
Pentaxophile
Posted 08/03/2011 - 09:53 Link
Very nice. I presume you had to use a tripod anyway, so why didn't you use a lower ISO to avoid having noise?
coker
Posted 08/03/2011 - 14:45 Link
Thanks Will.
Yes, I used a tripod(!)
I was after, as near as I could, points of light as opposed to trails.
Would lowering the ISO not have increased the exposure time?
The stars are already just beginning to trail anyway, @ 15secs.
Keeping the exposure time down, with lowISO, would also have meant recording only the brighter stars & I was keen to record as many as poss.
Does all this make any sense?
Roger.
Pentaxophile
Posted 08/03/2011 - 15:13 Link
coker wrote:
Thanks Will.
Roger.
Ah, I see now! Makes sense.
mikeyscope
Posted 08/03/2011 - 15:37 Link
Hello Roger
Really nice images.
I think you probably struck the best compromise ISO versus exposure time...always compromises.
The only way to record more stars while lowering your ISO is to increase exposure time slightly by mounting your camera on an astronimical motor drive of some description ...but the compromise ...well you house & trees would suffer motion blur.
In the good old days of film your fixed camera exposure could have ran another 5 to 10 secs without showing too much trailing as the star were hidden within the bloated halated star image but because DSLR sensors resolve so much better than film there is no room for error.
To record the red colour (hydrogen wavelength) in the Orion nebula a DSLR sensor needs to be modfied which is better done with an old inferior camera like a Canon 450D than a K7 as the process is not reversible
Unfortunately Canon are the only manufacturer supported by astronomical filter manufacturers because relatively few have used Pentax & Nikon for astronomical photography.
coker
Posted 08/03/2011 - 16:02 Link
Thanks, Mike.
Compromises all the time!
Do you have any of Orion, taken with your kit, i.e. telescope?
Roger.
Edited by coker: 08/03/2011 - 16:04
mikeyscope
Posted 08/03/2011 - 17:27 Link
Hi Roger
Nothing taken with the K5 & scope yet but hope to do so before Orion slips away for another season.
Just trying to get to grips with the K5 limitations using the 18-135mm lens before going up the focal length.
