Spots visible in viewfinder but not in photo
CoDa
Posted 05/11/2009 - 22:51 Link
I have just seen spots in the viewfinder but these do not show in photo. I have cleaned the mirror and screen above this but spots are still showing.
Should I get the camera cleaned inside? Or ignore it? Could there be a possibility of these specks or spots getting on to the sensor? Any advice or help please
Colin
Colin
Edmund Burke (1729 – 1797)
Hardgravity
Posted 05/11/2009 - 23:24 Link
Ignore them if you can, it's probably dust behind the focusing screen.
You can remove it to clean it, but it's fiddly and you risk damaging the screen, I know from experience!
Cheers, HG
PPG entries.
jackitec
Posted 05/11/2009 - 23:30 Link
So do I don't go anywhere near it with a rocket blower
Jack.
Edited by jackitec: 05/11/2009 - 23:31
imagesteve
Posted 06/11/2009 - 06:49 Link
You can have it cleaned or even replace your focussing screen but it is just gonna appear again after a few hours of usage. DO NOT attempt to clean it yourself, more damage than good will be done!
All the best
Imagesteve
2x K10D bodies, 2x FA 28-200 3.8-5.6, DA 18-55, A 50 F2, 50mm Macro, 360 FGZ. Still saving for the 60-250 DA* Also have a Z10 35mm and a K1000 just for fun. IF PENTAX IS THE ANSWER, WHO CARES WHAT THE QUESTION IS...!
CoDa
Posted 06/11/2009 - 09:04 Link
Hi All,
Thanks for the warnings and advice, I will leave as is.
Colin
Colin
iceblinker
Posted 06/11/2009 - 14:12 Link
The screen and behind can be cleaned just by flipping the screen down. No need to remove it completely.
A quick blow with a Rocket Boower or sweep with a clean brush may work or not work, but is unlikely to do much harm. A statically charged brush (like the Arctic Butterfly) can work well.
~Pete
Hardgravity
Posted 06/11/2009 - 17:23 Link
Last time my screen flipped down it fell out, on a walk!
If you try Pete's suggestion be VERY careful.
Cheers, HG
PPG entries.
