Spots
Posted 02/08/2018 - 14:43
If your camera has the dust detection system (I think K-5 onward) then it shows it as if you were looking at the sensor. It does all the reversing for you.
Posted 02/08/2018 - 16:47
But only if using the dust detection system; if looking at an actual image, then it is as Jimd says.
Andy
Posted 02/08/2018 - 17:09
alfpics wrote:
Very true. I meant to add use both for a comparison. See if the dust alert shows the same spots.
But only if using the dust detection system; if looking at an actual image, then it is as Jimd says.If your camera has the dust detection system (I think K-5 onward) then it shows it as if you were looking at the sensor. It does all the reversing for you.
Posted 03/08/2018 - 08:18
Cheers. The spots are on my K5 but don’t show up on the detection.
Newport,
South Wales
