Split Image Focusing Screen for K10D
Posted 06/03/2007 - 10:53
Of course the AF works. No problems.
blende8
Lens-Buying-Enabler, retired
Admission executive of the "Kate IS/WAS/AND CONTINUES TO BE WONDERFUL" Nutters Club
Posted 06/03/2007 - 11:50
Many thanks
I know it may have seemed a simple question but I have generally found that it's the simple things that can cause the biggest problems.
As it isn't one of their listed accessories I was concerned as to why!
Posted 06/03/2007 - 12:03
Because spot metering can be irritated due to darkening of one of the prisms in dark situations. As it isn't one of their listed accessories I was concerned as to why!
Metering goes through this screen.
blende8
Posted 06/03/2007 - 12:51
I use spot metering in generally light situations and centre weighted when using flash.
Will it have any affect in those situations?
Posted 06/03/2007 - 13:51
As I said, spot metering can be affected. Difficult to predict.
But why do you use spot metering anyway?
Matrix metering works very good.
blende8
Posted 06/03/2007 - 15:37
I use spot for wildlife and birds. Especially in Africa where backgrounds can be very strongly lit or birds against a bright sky.
In those situations I find spot very useful and far more acurate than other methods.
Posted 15/03/2007 - 13:04
My new split image screen has turned up
Scary moments taking the old one out but the wife's padded craft tweesers did the job
Fiddly but i's now in place and working great - exposures are fine, auto focus is faster and manual focus is much easier and faster
Highly recommended and much better than I expected
Posted 15/03/2007 - 13:40
mmm interesting, it shouldn't make any difference to AF speed since the AF sensors are in the body and not the Pentaprism housing.
if you don't mind my asking, how much did you pay for the screen?
Posted 15/03/2007 - 14:16
As Mongoose says it shouldn't make any difference to focusing speed but it does! Someone somewhere will probably know why.
It cost £18 inc delivery from e-bay
http://cgi.ebay.co.uk/New-Split-Image-Focus-Screen-Pentax-ist-D-DL-K10D_W0QQitem...
Posted 15/03/2007 - 17:32
good heavens thats 1/4 of the price of a Catz Eye screen.
How hard was it to fit?
Posted 15/03/2007 - 18:37
Absolute doddle to fit even for my clumsy hands
It looks just like the katz eye as well - but doesn't have the little tag at the bottom.
1. Take the lens off
2. At the top centre front under the penta prism there is a silver coloured latch - hold the camera upright and pull latch towards you with a small screwdriver (the screen mount will now drop downwards under its own weight)
3. With a pair of felt (or similar) padded tweasers lift the screen from the mount (ie don't touch the screen)
4. Put in the new screen with the matt side up
5. Push the mount back into place
6. Put the lens back on
Seems scary but very easy. Just mind you don't get dust on the pentaprism or touch the mirror with you fingers.
Posted 15/03/2007 - 21:11
The following information appears on the katzeye website regarding it's effect on metering. Have you found any problems with this screen?
Because of the presence of the prisms, the Katz Eye™ focusing screen for the Pentax K10D will have some effect on the camera’s light metering. Test results for each of the three metering modes are as follows:
* Center Weighted Average (CWA) Metering Mode: Our testing showed CWA metering mode to be accurate for all AF lenses having a maximum aperture of f5.6 or larger (lower f number).
* Evaluative Metering Mode: Our testing showed evaluative metering mode to be accurate for all AF lenses having a maximum aperture of f5.6 or larger (lower f number).
* Spot Metering Mode: Our testing showed spot metering mode to be within factory tolerance for all AF lenses having a maximum aperture of f2.0 or larger (lower f number). Lenses having a maximum aperture smaller than f2.0 (lager f number) will show a significant shift toward increased exposure, with the shift increasing for lenses with smaller maximum apertures. Spot metering mode is NOT RECOMMENDED when using a split prism focusing screen with lenses slower than f2.0. However, if spot mode must be used, it is strongly advised to first take a test shot, check the histogram, and adjust exposure compensation as required.
Posted 16/03/2007 - 08:14
Centre weighted and evaluative are both fine even on my f5.6 200-400mm
I just tried spot metering and it does over expose by about 1.3 - 1.5ev on all my lenses. Not a problem once you know about it.
I shoot in raw as well so if I forget then I can easily recover the shot with Silkypix.
Posted 16/03/2007 - 09:13
mmm so tempted.
looking at it objectively, I use MF far more often than spot metering, so really it should be a net gain
Wiltshire
I used to love these on the ME Super but am unsure as to what would happen to the AF if fitted to the K10D.
Can anybody tell me if the AF will still work :
