Spectacles and Eyecups
Posted 23/05/2012 - 09:42 Link
Having just started to wear glasses pemanently I am having difficulty using the viewfinder.
Problems are;
Due to light leakage I cannot read information in viewfinder.
Light leakage causes incorrect metering and exposure.
Light leakage makes subject difficult to see amd focus on.
I have searched this Forum and the internet but cannot find anyone who makes an eyecup for Pentax cameras which are designed for spectacle wearers. I found this non-UK ebay item but am not sure if it's large enough for use with spectacles. http://www.ebay.com/itm/6-in-1-Eyecup-for-Canon-Nikon-Sony-Pentax-Olympus-DSLR-/...
Any suggestions home made or not very welcome.
My camera is a K7
Regards David
Edited by davidrobinson: 23/05/2012 - 09:45
DoctorJeff
Posted 23/05/2012 - 09:58 - Helpful Comment Link
Having worn glasses since the end of WWII, I can tell you that I have not yet found a perfect solution. IMHE, it is harder to use binoculars than almost any viewfinder.
Still, for about £4, why don't you give the item that you linked a go?
X-5
istDS
K2000
P50.
Posted 23/05/2012 - 10:05 Link
An alternative is to remove/lift glasses when taking a photo - you will need to set the dioptric adjustment on the rear of the viewfinder (to match your eyesight) but you may find this a more comfortable/natural solution.
steven9761
Posted 23/05/2012 - 10:28 Link
What LENNYBLOKE says, +1!!
SteveLedger
Posted 23/05/2012 - 10:48 Link
Exactly what I do.
Hardgravity
Posted 23/05/2012 - 10:53 Link
I don'thave a problem with glasses and viewfinders.
The only thing that bugs me is theoblong shape left on my glasses by the standard K200 eye piece!
Cheers, HG
PPG entries.
johnc765
Posted 23/05/2012 - 14:40 Link
The dioptric adjustment, I take is the little slider on the viewfinder?
if thats the case I take it use autofocus on an abject then adjust it so its crystal clear in the viewfinder?
Smeggypants
Posted 23/05/2012 - 14:42 Link
No adjust it so the viewfinder screen ( markings ) itself is as sharp as possible. Have the lens out of focus on a white background or something.
Algernon
Posted 23/05/2012 - 14:48 Link
Either way works With a 2x Refconverter it's better
to focus on some lettering.
Frogherder
Posted 23/05/2012 - 16:03 Link
Now all we need is a screen cover to stop greasy nose marks
Bernard
johnboy-22
Posted 23/05/2012 - 16:36 Link
I used to push my specs up. Then one day while taking pictures out on some rocks at low tide I went to push them back down and they had vanished. The new ones cost more than a DFA 100mm F2.8 Macro WR. Now I leave them in the car and the only time anything is in focus is when I look through the lens.
Pentax K5, Kx, DA15 ltd,18-135, 18-55, 50-200, M100 f4 macro, M135 f3.5 A28 F2.5
tomkeet
Posted 23/05/2012 - 18:26 Link
Hi David, if you are thinking of the type Eye Cup in your link above, have a look at the JJC EP-2 22mm Rubber Eye Cup found them slightly better quality link
Regards, Tom
K-1ii,K-3iii's.
SMC PENTAX-F 1:2.8 28mm, HD Pentax-D FA* 1:1.4 50mm SDM AW,
SMC PENTAX-D FA MACRO 1:2.8 100mm WR,
SMC PENTAX-DA* 1:4 300mm ED [IF] SDM,
SMC PENTAX-FA* 1:4 600mm IF & ED,
HD PENTAX -DA 1.4x AW AF REAR CONVERTER,
Pentax Photo Gallery
cedricd
Posted 23/05/2012 - 18:44 Link
It`s a challenge and I too push up my specs. Trouble is in bright sunlight I like to wear a peaked hat to shield the sun so pushing up the specs doesn`t work. Could do with a stand off viewfinder this would stop the greasy nose prints. I often use the eyecup from an ME.
Enjoy life
Posted 23/05/2012 - 19:53 Link
Hi Tom
This looks ideal if its big enough to limit light leakage around the spectacles, do you use this eyecup and do you wear glasses?
Regards David
tomkeet
Posted 23/05/2012 - 20:44 Link
Hi David, it is slightly larger than the 6-in-1 type Eye Cup and the Rubber is softer.
I only wear glasses for reading but use the JJC Eye Cup all ways on the 600mm.
Quick comparison shot, JJC lower one.
link
Regards, Tom
K-1ii,K-3iii's.
