Southwell Minster
Posted 30/04/2009 - 08:01
Hi Richard,
I like nr. 1 and 3 the most.
Nr. 1 could use a bit work on the highlights(towers) and shadows(gate) to balance the shot a bit. But it is difficult with such a large contrast range.
It is manageable in PP.
Nr.3 shows the greatness of the church. It just needs more space to breath at the top (more sky) and bottom (beneath window).
Now it has a very enclosed feeling which is opposite to what you want to show. At least....that is what I think, you wanted to show.
Adding extra sky at the top is fairly easy.......PP wise. Bottom line, you should have stepped back a bit more.
HTH,
Martin.
HTH,
Martin.
Posted 30/04/2009 - 14:37
I find the shadow/highlight adjustment layer IN CS3 sometimes works a stunning treat, and sometimes just looks plain odd, but it is always a good place to start for that sort of issue.Nr. 1 could use a bit work on the highlights(towers) and shadows(gate) to balance the shot a bit. But it is difficult with such a large contrast range.
Nice shots though, and No 1 would be my favourite once the hightlight/shadow balance is resolved a little.
Cheers, Kris.
Posted 02/05/2009 - 14:06
I'll have a go balancing out the shadow/highlight and adding some sky to no 3. I don't have Photoshop, I'll try the shadow/highlight tool in rawtherapee and maybe look for something similar in GIMP.
Thanks,
Richard
Thanks,
Richard
Ludwigsburg,
Germany
All taken on K20D with 16-45mm lens
