Solution plesae
Posted 07/04/2011 - 15:50
This sort of thing is quite common and usually the result of using a wide angle lens at an off-square angle, ie., pointing up or pointing down. As a consequence you will never line up the two parts of the image. The only solution is to judge by eye what looks right, even though something may well be out of true.
Don't forget that lots of modern zoom lenses are not rectilinear either, so they bend straight lines, especially near the edges.
A possible solution is to use Photoshop Transform>Distort to "correct" the image as you seee fit.
Posted 07/04/2011 - 16:04
or use distort in ps
regards
Roy
Pentax K3 gripped,and some lenses
https://www.flickr.com/photos/pentaxroy/
my pbase gallery
Roy
my pbase gallery
Posted 07/04/2011 - 17:18
Lightroom's Horizontal perspective control will sort that easily.
Although to be honest why should the bollards be horizontal? The second pic looks fine to me.
Posted 07/04/2011 - 17:45
apart from the house is sloping too.
regards
Roy
my pbase gallery
Roy
my pbase gallery
Posted 07/04/2011 - 22:48
Thanks guys for the feed back this shot has frustrated me many times. I dont have a copy of photoshop yet but may be able to work something out in Serif.
Ian
Ian
Posted 07/04/2011 - 23:26
suggest you shoot it with the 10-17 fisheye.
Posted 07/04/2011 - 23:38
Have you tried shooting from further along the path (to the right) and making sure the camera is perpendicular to the street. Other than that a bit of skew should sort it out. I think Serif has a skew function, or you could try freeware like GIMP. (Why buy software these days when people make it available for free!)
Posted 08/04/2011 - 00:32
I just had a play, and by using the free transform and distort functions in PSE 8 it took about 2mins to do.
Colin
Edmund Burke (1729 – 1797)
Posted 08/04/2011 - 14:56
Ian
Sorry that I'm a little late coming in on this but would like to assure you that Serif (presumably a version of PhotoPlus) is well up to the job. I had a quick play last night with PhotoPlus X3 and following technique worked wellThanks guys for the feed back this shot has frustrated me many times. I dont have a copy of photoshop yet but may be able to work something out in Serif.
Ian
1) Open image
2) Create duplicate layer
3) Add a layer mask to this layer
4) Select the new layer
5) Activate "mesh warp" tool and pull the bottom corners of the image very slightly to the left until the bollards and house are vertical
6) Make background layer invisible by clicking "eye" icon
7) Select black as the foreground painting colour and paint out everything in the image that you want to to remain unaltered, making it transparent. I erased everything down to the top of the house.
8 ) Click the "eye" again to make the original layer visible.
Job done. The advantage of using layers is that this leaves the original image unaltered and nothing's lost if you mess up.
Hope this helps
Al
Posted 08/04/2011 - 15:03
You could also try http://pixlr.com which is free, online, and pretty impressive!
Posted 08/04/2011 - 15:52
Aero wrote:
1) Open image
Hope this helps
Al
[IMG]http://i23.photobucket.com/albums/b399/philstaff/revamp.jpg[/IMG]philstaff wrote:
Ian
Ian
1) Open image
Hope this helps
Al
Managed to follow your lead and think I may have solved it thanks for the info which was very helpful. Also a big thanks to all you guys for the feed back very kind of you all.
Ian
[IMG]http://i23.photobucket.com/albums/b399/philstaff/a-2.jpg[/IMG]
I have took the above photo many times but have not found a way to be able to get a correct horizon without the bollards looking out. Or getting the bollards straight in photo and then getting an uneven horizon. Can anyone offer a soplution please.
Ian
