SMC Takumar 28 f3.5
Posted 13/05/2009 - 15:24
If the lens has a rotary lever on the mount for open-aperture metering, which an SMC one should, then it won't budge and shouldn't unless fitted to a stop-down metering Spotmatic.
The lens is intended for the Spotmatic F and the A/M lever is not needed except for earlier bodies. Don't try to force it, but fit it to a Spotmatic or Spotmatic II (or derivatives) and then it will move.
Posted 13/05/2009 - 15:30
See your PM's
Probably worth writing this down here for the benefit of others though:
Auto-aperture Taks have a tiny pin (in addition to the pin that operates the aperture) on the rear that protrudes by about 1mm. When this pin is "up" (ie lens unmounted) it locks the auto/manual switch. When the pin is depressed (mounted on camera or adapter) the switch is free again. Never attempt to force the switch if the pin is in the up position or you'll break it!
I'd say yours would set you back somewhere in the region of £40-60 depending on condition
Joining the Q
Posted 13/05/2009 - 15:37
Forumers, I am ever grateful for all your wise directions.
K20D and a substantial user manual to wade through
Near Guildford,
but not quite...
Came with original case (no strap) and both caps. Anyone have an idea how much these usually go for, as this is my first Tak lens?
