SMC M35mm f2
bjolester
Posted 30/05/2013 - 12:27 Link
I recently acquired this lens, mostly because I do not have any primes at 35mm. I wonder if somebody could tell me something about this lens? For instance, what kind of usage is this lens meant for? If I decide to sell the lens, how much do these lenses go for?
Bjørn
Bjørn
Posted 30/05/2013 - 12:40 - Helpful Comment Link
It's a standard lens on Pentax DSLRs, giving a normal appearance similar to what is seen by the human eye.
walkeja
Posted 30/05/2013 - 13:32 Link
I ahve never understood that expression as each person is different. For me, 20mm givbes what I see on 35mm film!
Pentax K1-ii and MZ6
ONE UNITED Member
Pentaxophile
Posted 30/05/2013 - 13:45 Link
I think the phrase relates to the effect on perspective, ie how the image shows the sizes of objects relative to each other. A telephoto will compress the space between the subject and the background, and a UWA lens will exaggerate that distance. A 50mm is supposed to offer a natural perspective although compared to what we see, it's a narrower field of view on film, let alone APSC.
I guess 35mm is a good compromise between a natural perspective and a field of view which seems natural. I think you're absolutely right though John - every person is different in terms of where they think that compromise should lie.
bjolester
Posted 30/05/2013 - 13:50 Link
Thanks John!
I know that the K35mm f3.5 is a very good/superb landscape lens, maybe much in the same manner as the K28mm f3.5 (which is my favourite legacy prime). But what about the M35mm f2? At about f8 it is sharp from centre to border, and is quite useful for landscape. For distant motives/infinity at f2 it is sharp in the centre, but not so sharp in the corners. For close objects/portraits f2 gives good results with a pleasing bokeh.
When this lens was made, was it meant to be an all-rounder, a portrait/interior lens, or maybe something else?
Bjørn
Bjørn
Edited by bjolester: 30/05/2013 - 13:55
Posted 30/05/2013 - 14:04 - Helpful Comment Link
It would have been a "wide standard" that was favoured by some street photographers. Some people preferred 35mm to 50mm. I preferred 55mm, but it just goes to show that we can all see things differently!
A standard lens generally performs very well and can be somewhat abused with close up lenses, extension tubes, reversing on bellows and so on, without too much quality compromise.
The 35mm f/2 probably is weaker in some respects than the f/2.8, just as the 50mm f/1.7 has a better overall performance than the f/1.4. The wider aperture lenses come into their own in reportage and low light work.
bjolester
Posted 30/05/2013 - 14:11 Link
Thanks John, this was the information I was looking for!
Bjørn
Bjørn
Gamka
Posted 30/05/2013 - 14:38 - Helpful Comment Link
Bjørn
Late 70's to early 80's and replaced the k35 f2 which was about 50% heavier and 30% longer with a different set of elements. It then, I believed transformed into the A35.
walkeja
Posted 30/05/2013 - 14:54 Link
Dyslexic fingers. Sorry
ONE UNITED Member
Posted 30/05/2013 - 15:16 - Helpful Comment Link
Here's the script from the Pentax lenses and Accessories booklet:
With its natural perspective and wide angle of view, a Pentax 35mm lens is versatile enough to be used as a standard lens, especially when photographing in close quarters. In both f/2 and f/2.8 speeds and with or without automatic aperture control, Pentax 35mm lenses are compact and of excellent optical quality.
