smc DA 55-300mm f/4.0-5.8 ED
Posted 22/04/2010 - 16:32
Posted 22/04/2010 - 16:41
Take a look at the shots that Yve has posted in the Gallery, I think that will give you an idea of how good this lens is.
Regards John/Jumbo
Posted 22/04/2010 - 16:47
I'd rather the Sigma 100-300mm f/4 constant, or any make 70-200mm F2.8 + 1.4x TC instead. Barring that, this one comes next in line. That's saying something as those are some serious pieces of glass! Not to mention they cost 3-4x the amount of the DA 55-300mm.
K-5; Siggy 10-20 f4, 30mm f1.4, 18-50mm f2.8, 70-200mm f2.8; Tammy 400mm f4, 500mm f8
Posted 22/04/2010 - 17:10
As has been said many times on the forum, it's an excellent lens.
Posted 22/04/2010 - 17:23
As people have said, for the price it's excellent - and what hasn't been mentioned yet is that both its size and range make it very attractive when comparing it to superior glass such as the 70-200 f2.8's or the 60-250 f4.
However, I have found myself getting frustrated by its' performance a little of late. It's just not capturing the detail that my other zooms (DAs 10-17, 12-24 & 17-70) are, even when using a tripod. I guess this has something to do with the demands of the telephoto range. However, I would expect (not having had experience of the other long range lenses) that the faster lenses would perform better, and not only because of the wider aperture.
Unless a secondhand bargain arises, I anticipate my next new purchase will be something faster in this range to partly take its place. However, I'll definitely hang on to the 55-300 for both the convenient size and range, and the more than decent results when all things are considered.
Posted 22/04/2010 - 19:18
Used it for a nearly a year before changing it, great lens for the price.
Regards, Tom
K-1ii,K-3iii's.
SMC PENTAX-F 1:2.8 28mm, HD Pentax-D FA* 1:1.4 50mm SDM AW,
SMC PENTAX-D FA MACRO 1:2.8 100mm WR,
SMC PENTAX-DA* 1:4 300mm ED [IF] SDM,
SMC PENTAX-FA* 1:4 600mm IF & ED,
HD PENTAX -DA 1.4x AW AF REAR CONVERTER,
Pentax Photo Gallery
K-1ii,K-3iii's.
Posted 22/04/2010 - 19:23
I've got an 80-320 and my Dad has a DA55-300. The DA is better in every way provided you don't need full frame coverage.
In fact the DA is so good that in real world use it often takes a better photo than my Tamron 300 F2.8 prime. The prime is the better lens, but it's sheer size and weight make it hard to handle where the Pentax is light and agile.
but it does help
but it does help
Posted 23/04/2010 - 11:13
Many thanks guys and gels and any other sort that there may be. Advice taken and lense on order, will be delivered on Monday.
Thanks once again for all your help
Ian
Ian
Shepshed
Ian
