Slow shutter speed noise reduction k-3
Andy
I tried 20 sec exposures with/without NR in JPEG and RAW and the shutter was open for approx 20 secs in each case. So maybe K-3 is different or I don't understand what you meant.
Cheeers
Andy
The taking longer is, I assume, the processing time. Maybe I'll not really see it unless I accurately time and compare the shot times, as the K-3 processor is quicker than previous generations.
A quick Bulb test with NR on for >30 secs did not show any appreciable lapse after the shutter closed before it was ready to take the next shot.
Maybe the test I need to make is to actually compare the images closely for various settings. I was hoping to avoid this, if I could get a definitive answer. Got to get back to work now
It's a shame Pentax don't define functions like this ...
As your shots seem soft, it maybe something else, as assuming everything is stable, the NR simply subtracts any pixels that are bright when they should be dark.
The high ISO nr is something that can make an image soft.
Andy
Have a look at page 42 of the manual which deals with noise reduction and the settings options.
p42 is high I so not slow shutter that I can see ...
So the question remains, when in auto does it decide to apply it ? Anyway I can now see the function being applied so can experiment without having to laboriously check the the images.
Many thanks,
Barry
Andy
OTOH, High ISO nr is there to help reduce the random noise signal that a sensor has when you are applying a high level of amplification to it to get the high ISO performance. Hope that makes sense!
Andy
http://www.kadamsphoto.com/nightphotography/long-exposure-noise-reduction/
High iso nr is another matter. I'm now inclined to set this to off and fix in post as this noise isn't predictable and so a visual fix is likely to be better, albeit taking longer.
Time will tell if this works for me ...
BarryE
Member
Hampshire, UK
Does "slow shutter speed noise reduction" on k-3 affect RAW images ? If so when does it kick in ? In the ISO NR there's control of ISO speeds where it's applicable, but not for shutter speed NR - just auto or off.
I had assumed that it was only applicable to JPEGs, however I've just tried some long RAW exposures (30sec) and they were surprisingly soft. (All the usual movement "lock-downs" were applied.) So NR got me wondering ... As the manual does not make an explicit mention of RAW/JPEG for NR, I've inferred that it does indeed apply to RAW.
Anyone got any knowledge on this ? I'm guessing there's some astro photographers out there who'll know ...
