slow built in flash
gartmore
Posted 31/01/2007 - 15:11 Link
Just tried to trigger my new studio flashes (not to be confused with continuous lights anywhere else on this forum :wink and found that the built in flash on my DS now takes about 5 seconds to get out of bed. It could be that it has become arthritic through lack of use but has anyone else had this problem?
Posted 31/01/2007 - 15:19 Link
Do you mean that the pop-up mechanics are slow?
If so, I seem to remember reading something somewhere... hopefully I can find it again
gartmore
Posted 31/01/2007 - 15:24 Link
Yes, Matt, I do.
Posted 31/01/2007 - 16:07 Link
Ken,
Seems there was another:
https://www.pentaxuser.com/forum/viewtopic.php?t=1974
Not sure if it was resolved, but it sounds like a mechanical issue to me. On the K10D (which is probably similar) there's a small spring on the release catch side that does the actual "push" of the popup. There are also a couple of metal linkings that hinge from the flash head to the body - I suspect these are a form of "damping".
Maybe you should give someone like Asahi Photo a call and see what they say? Perhaps there's an easy solution... (here's hoping!)
spirit_of_will
Posted 31/01/2007 - 16:55 Link
I've had problems with an old Z1-P that had the same issue. It was a fairly cheap-ish fix done by Robin at Harrow Technical - think it cost me just under £30...
Spirit_of_will
My Flickr
Ammonyte
Posted 01/02/2007 - 11:47 Link
Sounds like a job for a spot of WD-40!
Tim the Ammonyte
K10D & sundry toys
gartmore
Posted 01/02/2007 - 12:29 Link
Thanks for the replies. I now think it really is down to lack of use - I've pushed it up and down a couple of dozen times and it is springing up more quickly, trouble is I cant remember just how fast it went up originally. I recall that we were always told to fire the self-timer on Spotmatics occasionally to stop them seizing so maybe the same applies here.
Rodger Fooks
Posted 01/02/2007 - 12:32 Link
There's room for a really bad joke here, but this is a polite forum so I won't
