Slide copying - best light source?
JohnX
Posted 25/08/2013 - 15:04 Link
I bought a slide copier - the tube type that fits on a camera body like a lens - and a quick play suggests that this will deliver what I want, but...
The but is that the exposure results are mixed, so I'm assuming I need a consistent light source of some sort - window light is too variable.
Any recommendations please?
Algernon
Posted 25/08/2013 - 15:15 Link
It probably won't cover the full frame with a digital camera.
I use a normal dome shaped low energy which is 2700-3200K
They are hard to find though so just try the biggest low
energy you can find.
JohnX
Posted 25/08/2013 - 16:07 Link
Thanks Algi.
Yes, the copier does crop, but for the majority of the slides I want to copy they seem to have been taken on cameras which had 80-85% viewfinders anyway, so losing what's round the edges is not a problem at all.
Do you shoot straight into the light source, of diffuse it?
In the interim, my wife has pointed out that we have a number of 'daylight' bulbs so I'll give those a try first as a source.
Algernon
Posted 25/08/2013 - 16:26 Link
Just straight at the Globe shaped bulb, but you could use a diffuser. I think my Pentax copier has a diffuser built in.
This is off a 1970 Kodachrome...
gartmore
Posted 25/08/2013 - 18:13 Link
I would use flash
JohnX
Posted 25/08/2013 - 18:17 Link
gartmore wrote:
I would use flash
Thanks Ken.
Directly into the device, via a diffuser, or bounced off a white surface?
Full power?
gartmore
Posted 25/08/2013 - 18:58 Link
Via a diffuser of some sort, I say flash because you know what the colour temperature is
Algernon
Posted 25/08/2013 - 19:03 Link
You would still need a light for focusing/cropping.
Flash will also emphasize any dust or scratches.
Which is one of the reasons diffused enlargers
were so popular.
I did a Custom WB for the bulb I used, by trial and
error. Try 3500K.... 3200K ..... 3000K etc.
This one link would be ideal.... it's DAYLIGHT 6500K
about £11.50 delivered.
If you use RAW you can also correct the CT during
editing.
Edited by Algernon: 25/08/2013 - 19:06
Algernon
Posted 26/08/2013 - 08:14 Link
It's worth making some sort of test slide to line up the
copier. This is a rough shot of a Novoflex one.....
Another Spotmatic shot off the same 1970 Seville Kodachrome film
as above....
Algernon
Posted 26/08/2013 - 08:46 Link
Same day different make of film.... Same Black Spotmatic..
Edit: Looks too purple in Firefox? The original isn't?
That one was just off a JPG not RAW.
Edited by Algernon: 26/08/2013 - 09:04
Posted 26/08/2013 - 09:40 Link
Kodachrome doesn't scan well, which is why some scanners have a dedicated setting for it.
The second shot looks too purple in IE as well. It looks like a very faded colour slide, or maybe a mismatch of colour spaces.
gartmore
Posted 26/08/2013 - 21:06 Link
John, I've always had amazing results from Kodachrome using the default settings on my Minolta dimage IV using the supplied Minolta softwRe
Posted 26/08/2013 - 22:24 Link
Good to hear Ken. We have a Coolscan V and it has a Kodachrome setting. In this case it does produce a better result on that setting, but I guess that's what it's set up for.
