size required for panoramic prints.
Posted 22/08/2007 - 13:20
CORRECTION TO MY EARLIER POST
Paper size will be 18 x 12 giving 2 prints of 18 X 6. Everything else is correct. I get dafter every day
__________________________
Best Regards
Skronk
Best Regards
Skronk
Posted 22/08/2007 - 16:15
In Photoshop you could create a 18 x 12 image comprising two 18 x 6 pictures.
Posted 22/08/2007 - 17:15
John,
Not to put too fine a point on it............How????????
Best Regards
Skronk
Best Regards
Skronk
Posted 22/08/2007 - 17:22
First, prepare your two images and crop then to the size you want. 18 x 6 at a resolution of 300ppi. (This is done in Image>Image Size)
The create a "piece of paper" to put them on. This is created by going File>New and then defining the size of your paper (18 x 12 at 300ppi)
Now drag and drop your two images onto the paper using the Move tool. Make sure they are lined up properly. Then Flatten the image as at this point you will have three layers (the background, Image 1 and Image 2).
Save As a TIFF.
Easier to show you than describe it, but I hope that helps. If you are in doubt about any part of that, just ask.
Save As a TIFF.
Posted 22/08/2007 - 17:58
Thanks John,
I think I follow your instructions. Should I save as a Tiff if the processor requires Jpeg?
Thanks again
Thanks again
Best Regards
Skronk
Best Regards
Skronk
Posted 22/08/2007 - 18:08
No, save as a JPEG if that is what is required.
What you could do is save your original as an uncompressed TIFF and then save under another file name the JPEG version for the processor. Best of both worlds then.
Posted 22/08/2007 - 18:18
Do all your editing in psd, tiff or a similar format and only make the finished product JPEG.
Posted 22/08/2007 - 19:15
Thanks for the assistance gentlemen. Greatly appreciated.
Best Regards
Skronk
Best Regards
Skronk
Isle of Skye
I make up panos using Panorama Factory and then will attempt to place them into PS7.(god help me!) but am unsure of dimensions
Best Regards
Skronk
