Single shot whith HDR
There used to be a software program written in Java
and only supporting Intel CPU's (Lightzone.. hardly
surprising that they seem to have disappeared )
that allowed you to manipulate Zones individually
which is probably a similar thing.
EDIT:: It seems Lightzone may now be available for
FREE once they sort out Licensing Problems
http://en.wikipedia.org/wiki/LightZone
It was quite a powerful program which won quite a
lot of awards. I'm sure AP picked it as the Best
Photo App one year.
Old Review:
http://www.photozone.de/lightzone-v205
Here's a very quick attempt with more conventional means. It has just 0.25 stop more exposure and some texture pulled back into the highlights as that was explicitly mentioned in the OP. I did notice the HDR tonal mapping gave a benefit in putting some texture into the reds and making explicit the front and back red panels so I've done a bit of the same thing by steepening the tonal curve a touch at the red panels brightness point. I've probably made the red and yellow a bit too bright in doing so but it's only a quick play.
Here is one picture (single shot) runned through easyHDR with dramatic dark settings vs. original picture.
With easyHDR:
I like it. I wouldn't even class it as HDR, but just regular processing to reduce teh dynamic range.
It's nice to hear others opinions.
On that picture there are some elements that dosen't look very natural as Bob (gwing) said, like birch bark (too light, IMHO).
Jukka
flickr
"If your photographs aren't good enough, you're not close enough." - Robert Capa
13 years
Äänekoski,
Finland
With easyHDR:
and original (not processed) photo:
Jukka
flickr
