Sigma EM-140DG Ringflash...
Posted 19/10/2010 - 20:48
Hi Chris, that sounds very tempting, although being a bit of a luddite... how does the flash attach to the front of the lens? Does it use the filter thread? and if so, does sigma produce an adapter for 49mm threads? I use the DFA 100 macro a lot but that has a 49mm thread; and I am not sure whether that lens is (dare I say it) robust enough to have a flash hanging off the moving front element? Or does it connect some other way?
Any advice appreciated!
Posted 19/10/2010 - 20:58
Hi Mat,
It uses the filter thread and the flash comes supplied with 55mm and 58mm rings. You can either use step-rings to use with the supplied rings or purchase other ones which match the filter thread of your lens. We sell all sizes which range from 52mm to 77mm.
Hope this helps!
Hope this helps!
For all things Pentax please visit www.srsmicrosystems.co.uk - anything not listed please email or call!
Follow us on Facebook
Posted 20/10/2010 - 10:27
Chris@SRSWATFORD wrote:
Hi Mat,
Hope this helps!
Chris - so are you saying that it wouldn't fit a DFA 100 macro 49mm thread?
Hi Mat,
Hope this helps!
Posted 20/10/2010 - 10:51
It certainly should fit. you only need a 49mm step up ring. I believe Mike-P has this flash and a DFA 100mm macro if I am not mistaken.
Camera:|K-7|
Posted 20/10/2010 - 11:06
Hi Clarky - thanks, just Chris's post was a bit ambigious
Posted 07/11/2010 - 22:21
I have just got this flash and used it on my 100mm Macro with a step up ring and it is fine and I would not put my prcious macro at risk .Hi Clarky - thanks, just Chris's post was a bit ambigious
The step up ring I had one but ordered one of fleabay £2.98 just getting to know this flash but I mst admit I like it
All the best
20 years
Watford
I've just had some more stock of this ringflash at the special price of £199.
http://www.srsmicrosystems.co.uk/2229/Sigma-EM-140-DG-Macro-Flash---Pentax-Fit.h...
As usual, post free to mainland UK.
Any questions, please ask!
Chris
