Sigma 50mm focusing issue
Posted 20/05/2011 - 10:35
It isn't uncommon. The only way to be sure is to put the camera on a tripod and focus carefully with LiveView (if you have it) or the optical viewfinder. Use the widest aperture. Then try the autofocus, preferably by defocussing the lens first so that it has to start again - putting your hand in front of the camera and making it focus on that works. If you don't do that it will probably just use the focus setting you've just set manually.
Once you have some pictures with different focussing methods compare them closely.
Then post them here for discussion...
Posted 20/05/2011 - 10:47
I think the above reply sums it up but heres my two penneth anywyay.
I get the imprssion from the blurb on this lens that its more suited to portrait work.
From the lens description; It creates a very attractive blur, even when a small aperture is used.
Is that a clever way of saying its soft around the edges: are you sure its a focus problem and not softness?
Posted 20/05/2011 - 10:58
Lenses are designed for different purposes, but generally manufacturers are pretty vague as to how they describe them. If only they would come clean as to what the properties of a design are, then we could all buy the one that suits our purpose. First time....
Posted 20/05/2011 - 14:14
Tried it at all apertures and speeds and on a tripod as well. Softness at the edge isn't the issue - its the out of focus look dead centre thats the problem. Its a lovely portrait lens and thats pretty much it. With hindsight I'd have saved a bit more and gone for the 50-135 which would likely have suited me far better.
Posted 20/05/2011 - 14:21
Perhaps you could post an example image?
It doesn't sound right in that almost any modern lens, especially an expensive prime, should be able to produce sharp images as a matter of course.
