Shutter speeds/focal length/handheld
Posted 13/03/2011 - 21:30
It would be safe to do so.
However, being a larger format it should be affected less than 35mm or APS-C as you don't magnify the finished image as much.
Posted 13/03/2011 - 22:41
The logic of this is sound, but larger formats are often used on a tripod anyway. I always found I could use a Rollefilex fairly safely at 1/8sec. but the Spotmatic was always at least 1/30sec with the standard lens.
Posted 13/03/2011 - 22:55
Surely, the amount of shake is going to be less apparent on the medium format due to the field of view being larger for a give focal length?
Bob
Posted 13/03/2011 - 23:03
Yep, but bear in mind that I would still like to be able to crop and enlarge the negatives. I want to get the old enlarger back into action as early attempts to scan negatives proved tedious and unsatisfactory - the scanner just can't cope with the resolution needed if you then plan to enlarge the results. Scanning A4-sized prints made the old way should be much better.
It sounds as if 1/125 with a 150mm or 200mm lens would be safe enough though?
It's all to do with magnification. At the other extreme a Minox is quite vulnerable to shake, despite what we see being achieved in all those spy movies.
Posted 13/03/2011 - 23:04
It's fairly simple I think.
The height of a 135-format frame is 24mm. The height of a 645 frame is 45 mm. So where a 50mm lens on 135 requires (according to the "rule") a shutter speed of 1/50, on a 645 that would translate to 45/24 x 1/50 = 1/75 (approximately).
It's because 645 negs need 50% less enlarging than 135 negs.
On APS-C, the sensor height is 16.7mm, so the safe speed is 16.7/24 x 1/50 = 1/75.
Mid Wales
