Shutter release problem
K5iis shutter releases even with AF button and Half Press(focus priority) focus have both been disabled,
To disable both you need to turn the body switch from AF-S/AF-C to M, but then you cannot use CIF as the AF has to be "alive" on the camera body for it to work.
Pentax 17-70 SDM and Tamron 90mm Macro lenses tried. Am i missing something in settings. Trying to get CIF to work with the Tamron.
Check that you have enabled CIF in the menu.
shutter button half press set to OFF
stroud,glos
